Tim_Houston Posted September 23, 2014 Share Posted September 23, 2014 My Reference Floor Display color is black. How do I change it back to RED? Link to comment Share on other sites More sharing options...
GaryOhmer Posted September 23, 2014 Share Posted September 23, 2014 Open Layer Display Options - change Default set to Reference display set - select all - change color to what ever you want Link to comment Share on other sites More sharing options...
chief58 Posted September 23, 2014 Share Posted September 23, 2014 Tools> Layer Settings> Display Options to open the Layer Display Options dialog. under layer sets find the reference display set, select all and change the color Link to comment Share on other sites More sharing options...
Tim_Houston Posted September 23, 2014 Author Share Posted September 23, 2014 Thanks, Layers was the first thing I checked, not my issue. All reference displays are set to default red. This appears to be an issue moving my files from Mac to PC. Link to comment Share on other sites More sharing options...
dshall Posted September 23, 2014 Share Posted September 23, 2014 Thanks, Layers was the first thing I checked, not my issue. All reference displays are set to default red. This appears to be an issue moving my files from Mac to PC. Post unclear, did you figure it out? Link to comment Share on other sites More sharing options...
Tim_Houston Posted September 23, 2014 Author Share Posted September 23, 2014 Post unclear, did you figure it out? Negative. Issue is still here. http://screencast.com/t/tLOEhdk1jUJy Link to comment Share on other sites More sharing options...
MPDesign Posted September 23, 2014 Share Posted September 23, 2014 check your prefrences, appearance, color settings. the default is probably different than your old settings. Link to comment Share on other sites More sharing options...
dshall Posted September 23, 2014 Share Posted September 23, 2014 check your prefrences, appearance, color settings. the default is probably different than your old settings. the line style of the ref set is controlled by the ref set. Change the line style via your ref set. Preferences has nothing to do with it. Do you know how to access your ref set? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 23, 2014 Share Posted September 23, 2014 You can copy a layerset from any layerset you have if you want it to look like a drawing in the background, just re-name it to say" reference roof plan" or something that makes since to you. Then you line weights and style will match your plan. Link to comment Share on other sites More sharing options...
Tim_Houston Posted September 23, 2014 Author Share Posted September 23, 2014 Let's start this over. I have no color (black) when I select the reference floor display child in plan view. The layer displays in black. Layerset as posted shows RED. If I leave the display reference on and send to layout I see the red. I DONT see the red in plan view. Thanks Link to comment Share on other sites More sharing options...
dshall Posted September 23, 2014 Share Posted September 23, 2014 Hit F8, the color will come on. 2 Link to comment Share on other sites More sharing options...
Solution Tim_Houston Posted September 23, 2014 Author Solution Share Posted September 23, 2014 Hit F8, the color will come on. You the man! Thank you Link to comment Share on other sites More sharing options...
