Topography Control Problems
jjifmeyer
I have the hardest time trying to figure out topography and understand how to control IT PROPERLY. I have watched all videos and been at it for hours.
HELP…! Trying to control the height levels of certain topography aspects. An help would be appreciated.
I have watched videos but it is just not clicking.
Attached is my plan with a Screen Shot of what I'm trying to accomplish.
I am new to CA so a thorough explanation is appreciated.
Dave_Becky.plan
  • Use an elevation region big enough to include the road and sidewalk and snap it to the back of the Sidewalk ( house side) instead of the Elevation line.
  • You then need  a Terrain Retaining Wall coming out from either side of the garage door to the sidewalk , both these you need to edit in elevation ( section camera) to slope just above the terrain.
  • Then add a very narrow (6-12")  Terrain Region the width of the Driveway, outside the garage door, set 1.5" lower than the garage slab. ( this allow for 1" thick driveway next ,it sits on the terrain in Chief)
  • then add the Driveway from Garage Door to Curb.
6 hours ago, jjifmeyer said:
Thank you so much for your help.
Where I was going wrong is I thought the Terrain Wall auto cut the terrain.
Now it all makes sense
Thanks Again
Hi Jim , just to Clarify a Terrain Wall and a Terrain Retaining Wall act different..... so hopefully you noticed David used a Terrain Retaining Wall  ( as I did above) not a Terrain wall.
This video shows some of the basics and is worth watching all the way through , but the wall differences are shown at 13:44 though.
https://www.chiefarchitect.com/videos/watch/75/terrain-site-plan-basics.html?playlist=101
My retaining walls never work like this. The effect the terrain in weird ways but they never create a held back land area with fill in behind. There has to be more to the retaining wall thing than this. I have been spending hours on this and can not figure out how to simply draw a retained area with a stone wall.
Are you drawing an Elevation Line behind the retaining wall with the appropriate height?
I never use a Terrain Retaining Wall, I use a Terrain Break and then draw my wall manually (it doesn't have to be a retaining wall).
I always draw an Elevation Line just behind the Terrain Break at the appropriate height and one in front of the Terrain Break at the lower height.
A Terrain Retaining Wall is a normal wall with a Terrain Break incorporated.
More often than not, when using a retaining wall, the tops and bottoms will be broken into too many segments which then makes it hard to edit the wall top and bottom shapes.
Post a plan for better help.
