Sweeney Posted April 26, 2019 Share Posted April 26, 2019 Hey all, I am wondering if there is a relatively easy way to overlay a model on an image with the correct perspective lines in Chief. I know Sketchup has a photo-match feature that allows for this sort of thing. Can you export a chief model to a sketchup file? To people that have done this before, do you usually work most in photoshop when overlaying in Chief? Thank you in advance, Austin Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted April 26, 2019 Share Posted April 26, 2019 From my experience there is no simple way to do this but it can be done. This one was done almost entirely in Chief with few corrections in Photoshop. I took a Google street view and applied it to a very large P-solid on the other side of the road. By changing the size of the P-solid and the texture(pic) positioning I could get things looking reasonable. This one was done entirely in Photoshop. Rendered the model in Chief, placed it Photoshop and then on a separate layer I placed the background pic. It's tricky to get things to line up properly as there is a limit to how much one can stretch and warp a pic before. To get it right would take a real Photoshop pro. Link to comment Share on other sites More sharing options...
evergreen Posted April 26, 2019 Share Posted April 26, 2019 Nicely done Graham! Link to comment Share on other sites More sharing options...
joey_martin Posted April 28, 2019 Share Posted April 28, 2019 On 4/26/2019 at 8:50 AM, Sweeney said: Can you export a chief model to a sketchup file? Yes. Export the model as a 3DS file and import into sketchup Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 28, 2019 Share Posted April 28, 2019 Export as Collada. Import to Sketchup and select merge coplaner surfaces. Link to comment Share on other sites More sharing options...
EBinteriors Posted April 29, 2019 Share Posted April 29, 2019 Are you using https://hover.to/ ? I have used it in over 20 of my projects, it is now a regular feature of my workflow, I walk around a building and take 8 pictures with my Iphone, I get full dimensions hours later. Might cost $30 to $50 per measure. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 29, 2019 Share Posted April 29, 2019 16 hours ago, Decorationarts said: Are you using https://hover.to/ ? I have used it in over 20 of my projects, it is now a regular feature of my workflow, I walk around a building and take 8 pictures with my Iphone, I get full dimensions hours later. Might cost $30 to $50 per measure. Do you find the measurements accurate? Link to comment Share on other sites More sharing options...
EBinteriors Posted April 29, 2019 Share Posted April 29, 2019 Very close. I do internal measurements to check against. I also use Matterport for all my internal measures. Link to comment Share on other sites More sharing options...
