K80Guy Posted April 22, 2019 Share Posted April 22, 2019 Sorry if I'm posting this in the wrong spot but does anyone have any insight into spiral stairs. I'm working on a project that I want to put a set of spiral stairs leading from the main floor deck to the lower level walk-out. Customer doesn't want traditional stairs due to their size and they don't want to ruin the look. I've looked through tutorials but mostly talks about using the 3D spiral set in the catalog. Thanks for the help or information. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 22, 2019 Share Posted April 22, 2019 I can create a Spiral Stair Symbol for you. I just need the dimensions, direction parameters and desired style of railing. My charge for this is $100. Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 22, 2019 Share Posted April 22, 2019 I usually just use the symbol from the library and manipulate to look the best in 3D, then use a detail to give the specifics. I use this spiral stair calculator to speed things up. There were some great posts I believe in the old ChiefTalk site by Yusuf which may be this one (part 1) and this one (part 2) and this one (part 3). [EDIT] Or.., call Joe. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 22, 2019 Share Posted April 22, 2019 18 minutes ago, K80Guy said: Thanks for the help or information. Might need to create this yourself...or ping the master Joe...you can do it with landings connected to each other which will give you greater control Link to comment Share on other sites More sharing options...
Gawdzira Posted May 6, 2019 Share Posted May 6, 2019 Hopefully you did the smart thing and send the dimensions to Joe. If not, check this out 1 Link to comment Share on other sites More sharing options...
robdyck Posted May 13, 2019 Share Posted May 13, 2019 I know how to make them perfectly using Chief's tools but it's way too complicated to describe in a post. I'd jump all over Joe's offer, unless you work for under $10/hour:) and don't mind spending a whole day on it! You'd feel like a genius when all you have to do is import a perfectly fitting symbol! Link to comment Share on other sites More sharing options...
No1ZZTopfan Posted July 8, 2019 Share Posted July 8, 2019 Do you mean something like this? Link to comment Share on other sites More sharing options...
JJohnson Posted July 9, 2019 Share Posted July 9, 2019 On 4/22/2019 at 1:29 PM, K80Guy said: Sorry if I'm posting this in the wrong spot but does anyone have any insight into spiral stairs. I'm working on a project that I want to put a set of spiral stairs leading from the main floor deck to the lower level walk-out. Customer doesn't want traditional stairs due to their size and they don't want to ruin the look. I've looked through tutorials but mostly talks about using the 3D spiral set in the catalog. Thanks for the help or information. There are dozens here........... 3D Warehouse Collection of Spiral Staircases Some are pretty clunky, but you might find the style you want as a reference for someone to build on. Link to comment Share on other sites More sharing options...
yusuf-333 Posted July 10, 2019 Share Posted July 10, 2019 Well think symbols from a 3rd party will result model slagoahness. I know symbols made insode chief are better. I can make you pretty accurate spiral stairs. PM me. 1 Link to comment Share on other sites More sharing options...
