Apartments
kvolanti
How well does Chief handle apartments? I have a 16 unit 2 story apartment I am considering using Chief to build in. Other software I'm considering is Softplan and Revit. I want to be able to model the building and use it for construction drawings and getting quantities to get estimates of cost. Would chief be able to handle this type of building? Any articles or training docs/videos that you can link me to so I can see if Chief is right option?
Thanks for your help in advance.
Perhaps your question should be, how well does chief handles large files? Or, has anyone had experience with large buildings?
I certainly have not, we modeled an eight unit  three story complex and had to move it to ArchiCAD. Back then Chief and the computer or a combination thereof were not able to keep up.
Look through the Galleries and see who has large projects. The same goes for Softplan, and for the other one, unless I’m being paid a lot of money I wouldn’t bother even trying.
If you add all the detail to each apartment you might have speed issues.  OTOH, if you do a detailed plan for just 1 or 2 apartments (typical) and then show just the perimeter walls, doors and windows for the rest of the units it shouldn't be a problem at all.
This is the same procedure we used to use for such buildings when using manual drafting.
Personally would not recommend Chief...... not enough muscle ....... we have moved projects that  are not houses to VectorWorks...... enclosing several JPG's of what we did in Chief prior to the move. We are a design build firm and we must estimate accurately and to get accurate material estimates we also needed to look beyond Chief.
Thanks everyone. I still need to do more research but it sounds like Chief can handle the size of the model based on a few peoples comments. I have a powerful computer so I think the software will be fine. I'm still wondering how the material take-offs will be handled and Chief will be able to handle the amount of information.
Chief is one of the best design software for single family homes. For larger multi family projects you want to be in Archicad / Revit / Vectorworks.
Chief runs into problems with performance speeds in larger multi family projects. It is also not set up well to do copy/paste of identical units as the process generates a very large amount of errors that are time consuming to fix. In the multi family projects I have designed with Chief, we always moved to a different platform for building permit drawings.
Just completed a 74 unit project and now working on a 42 unit mixed use....
I think it works well if you are working solo and know the program a bit.
It does slow down once you add all the individual unit details/symbols...hold off on adding this stuff as long as possible.
I use a separate "detail" file that contains... well... details, notes, etc. to keep the main file size down (not sure it helps).
We do need a way of having a typical unit "block" that can be utilized
My guess is the other platforms like Revit slow down also when you have large models???? Maybe not.
I do find the size of Chief PDFs Con Docs to be way to large compared to other peoples work. I have to use drop box to distribute.
Eric
Apartment Plan C.jpgI cringe when I see 1/16" or 1/8" dimensions, even 1/4" is too small unless you are getting into the minute
i C
    31389
    LeighSupplies
    LeighSupplies
