Custom Material Generation with Substance Player
Chief_Content
General Updates
Update 7-20-2023
Removed the Beta tag from all the builders and put the Chief Architect tag in the file.
Tile_Builder Parameters
Here are some of the options you can adjust within the Tile_Builder_Beta.
Output Size: Drop down lists with resolution sizes.
Random Seed: Click the Randomize button to get different material images and tile layouts.
Shape: Choose the shape of your tile.
Tile Layout: Choose how you want your color and material types laid out.
Offset: Adjust the horizontal offset of your tile.
Tile Edge: Adjust the sharpness and size of your edge profile.
Grout Width: Sets your grout width.
Grout Color: Choose the color of your grout.
Tile Material: Selects different materials for your tile.
Tile Material Scale: Scales your material to make it larger or smaller.
Tile Color: Choose the color of your tile.
Tile Color Variation: Randomly adds variation to get non-uniform color.
Tile Finish: Drops down to different finish/glazing options.
Tile Roughness: Controls how shiny or matte your tile looks.
Tile Hue: Changes the hue of your color, good for fine tuning.
Tile Saturation: Changes the amount of color in your tile.
Tile Lightness: Changes how light or dark your tile is.
Update 1-12-2025
Tile Builder
-Updated to the most recent changes found in Chief
-Fixed the color picker so Porcelain and metal RGB values are exactly what's picked.
Update 11-26-2019
Tile Builder
-Dropped Beta tag
-Added a resolution drop down "Output Size" for bigger/smaller texture options
  • Higher resolutions will let you get smoother edges on non-square tile patterns and the added pixel count will allow for thinner grout lines.
  • Higher resolutions can also clog up your machine and Chief if you use a lot of them, so unless you aren’t getting the look you need, I’d stick with 512 or 1024 output sizes.  Map responsibly.
-Added Picket Tile and Penny tile to the shape drop down
-Changed “thin tile” to 4:1 tile
-Added a slider for Grout width.  Again, if you need thinner grout then what’s being shown, you’ll need to up your resolution under Output Size.
-Added a color selector for tile color, behaves just like the grout color options.  If you want an eyedropper, open the color selector and hit “pick.”
  • Color Hue is still included for fine tune adjustments.  Keep an eye on your hue if you eyedrop to another color and it’s not matching, more times than not your color is being skewed by the hue slider.
-Added a color variation slider to get some non-uniform color.  Randomly darkens some tiles to varying degrees.
-Added a finish drop down for hand glaze options.
Update 10-21-2020
-Added some new Shape options
               Changed Large Tile to 1:1 large Tile
               Added a 2:1 large Tile
               Triangle Patter
               Elongated Hex
               Elongated Diamond
-Added image inputs on each material drop down
               You should see a slot to add your image when selecting ~image input in the “Tile X Material” dropdown
-Added a Material Invert for those that want white marble with grey veining instead of Black marble with White veining, etc
Update 1-20-2021
-Added a "Material Scale" slider to each tile type
              Scale can be set anywhere from 0% to 500%
Update 10-31-2022
-Added more tiles to the 1:1, 2:1, etc so a 1/3 and 1/2 offset both work without breaking the seam.
Update 6-22-2023
-Added an "~Image Input RAW" as a material selection that will let you feed in an image and keep its color.  This selection bypasses the color picker and inverter control but everything else (hue/saturation/lightness/variation/etc) should work properly.
Update 04-10-2025
-Added preset Offset Dropdowns
-Unified function with the other builders
-Added a seam blender for the image inputs
-Cleaned up some UI, stuff that isn't active should disappear, etc.
Wood_Builder_Beta Parameters
Here are some of the options you can adjust within the Wood_Builder_Beta.
Wood_Species: Select the species of wood you’d like to work with.  Selecting "~Image Input" at the top lets you load your own images to feed into the builder.
Cut: Select what kind of pattern you’d like to make.
Material Scale: Adjusts the size of the texture/grain of the wood but not the board size.
Grain Prominence: Deepen the grain/detail color of the material.
Stain Color and Amount: Pick the color of stain and the amount to apply.
Hue, Saturation, Lightness: Adjusts the color of your wood.
Board_Color_Variation:  Varies the colors of the wood along cut lines to help show the pattern and ad variety.
Roughness: Controls the roughness or polish level of your floor.
Image_Input: Added a slot to enter your own wood images and slice/adjust them as needed.
Source Image Edge Edit: Only appears when an image input is being used.  Lets you keep the original edge of the edit or attempts to blend the edges together to make it seamless.
Source Image Orientation: Only appears when an image input is being used. Rotates the source image being used.
Knot Size and Frequency:  Adds knots to your material, and adjusts the size of knots.
Open Grain: Adds some grain prominence to the normal/ao maps (makes the grain have some 3d to it) for a more rustic feel.
Distress: Some general 3d distressing, works well with the Open grain slider.
Paint level: Adds paint to the material.
Paint color: Selects paint color.
Lichen/Mold: Adds gross stuff to material.
Update 1-12-2025
Wood Builder
-Added White Oak, White Oak Quartersawn, White Oak Rift Sawn
-Removed Knotty variations of all species
-Regrouped some controls into knots, surfacing and weathering, and adjustments
-Added Material Scale
-Added Grain Prominence, lets you deepen the grain color on the texture map
-Added Open Grain slider that adjusts the normal and AO map to add grain/knot depth
-Changed the name "Age" to "Distress"
-Added a Knot group with Independent Knot control, size and frequency
UPDATE 4-29-2020
Wood Builder
-Cleaned up a lot of the Knotty/Rustic options.  They were bad, they should now be less bad.
-Added an image input.  WoodSpecies needs to be set at "~Image Input" and you can load whatever image you want into the builder.  I recommend using seamless images, otherwise you might get some strange edges in your boards.
-Added a shiplap option in teh "Cut" dropdown
UPDATE 10-26-2020
-Added Resolution selection
-Added an Orientation selector
-Added "Weathering" effects sliders
Update 04-10-2025
-Added Stain color and Stain amount Sliders
Single_Color_Fabric and Multi_Color_Fabric  Parameters
Fabric Type: Selects different types of fabric.
Color: Selects your fabrics color
Color Hue: Changes the hue of your color, good for fine tuning.
Color Saturation: Changes the amount of color in your fabric.
Color Lightness: Changes how light or dark your fabric is.
Masonry_and_Stone_Builder Parameters
Here are some of the options you can adjust within the Masonry_and_Stone_Builder.
Shape: Choose the shape of your stones.
Pattern Layout: Choose how you want your color and material types laid out.
Stone Cleavage: Roughs up the face of the stone with more stone character.
Stone Roundness: Rounds off the edges of the stone.
Wany Edge: divides and warps the lip of the stone for more uneven looks.
  -Only on offset-able shapes.
Margin Fill: What shows between the stones.
Margin Width: how much space shows between stones.
Margin Hue: Changes the hue of your color, good for fine tuning.
Margin Saturation: Changes the amount of color in your Margin.
Margin Lightness: Changes how light or dark your Margin is.
Stone Material: Types of Stone.
Stone Roughness: Roughness of the Stone.
Stone Material Scale: Changes the scale of the character on the stune.
Stone Invert: Inverts the Stone Character.
Stone Color: Color of the Stone.
Stone Color Variation: Adds random variance to the Stone for variety.
Stone Hue: Changes the hue of your color, good for fine tuning.
Stone Saturation: Changes the amount of color in your Stone.
Stone Lightness: Changes how light or dark your Stone is.
  • Upvote 3
4 minutes ago, gelbuilding said:
Substance Designer is one of the best programs around for making materials. I have been using it for a few years now.
The materials I have been posting here are all made with this program.
does substance "player" have the ability to load your own textures?
16 minutes ago, gelbuilding said:
You need substance designer to build the graph and here you create your textures and export as sbsar file to open in the player.
Thank you, very helpful-
another question, will substance designer allow you to tile a texture while randomizing- this is the biggest time sap for me when creating say flooring textures or tile- it seems as if it does just that, which would be worth buying the whole suite for me
btw- not fair that I've been living in the dark ages under a rock all this time :ph34r:
Yeah this was a huge problem when I started.  You need to know how to setup the graph in order to randomize the textures across the tiles.
The sbsar CA have posted was made in substance designer and when exporting out to sbsar file you can expose parameters to see in substance player.
You expose parameters to any adjustments that are required.
54 minutes ago, gelbuilding said:
Be good if we could use displacement maps in our materials when rendering. Would give a bit of depth to the renders.
Would be great to add the slot for displacement or height maps in the program CA.
I try and avoid displacement maps as much as possible, just introduces so many problems, especially with CA geometry. CA would likely get a lot of tech support calls...
Clipping masks and multiple diffuse layers for one material on the other hand would be a big ask for me
I love the Tile Builder! I got to use this last summer when I went to Chief's training in Coeur d'Alene (Dustin's whole talk was great). I have used it several times since. My favorite outputs have been my cobalt porcelain hex and my copper hex (shiny copper mixed with flat grey slate).
I would LOVE more substance players! Particularity one that outputs 'pallet walls' which mix textures of natural and painted woods, like in the attached picture. I'd also love more shapes in the tile one, particularly arabesque tile, mermaid tile, and diamond tile.
  • Upvote 2
CreativeHomes - Glad you used it!  Wood flooring/paneling is on deck here shortly, I don't know about colored walls though but I'll keep it in mind.  For future tile, I think the plan was to offer more catalogs that house the more custom/exotic tile options.  This first one was just the basics.  If people end up using them I'll spend more time publishing more of the creative ones that we do in house.  Keep posting requests with pictures in this thread for me to use as reference.
Faruk - The gap/grout to tile ratio is currently static, so for a large tile like a 32" your gap will unfortunately also scale up in size.  When I get back in the office, I'll see about updating the Tile_builder_beta with something that will handle a large tile style correctly. Check back here next week.  Great request!
Here is a file I have been working on, Please note it's not perfect. If you export the maps in jpeg you will notice a few artifacts on the tile around the tile joint, best results in PNG
Maybe I'm trying to pack too much in one graph, lol
When first opening the file you will see the tile pattern is the french pattern. There are many adjustments you can make to the pattern, all self-explanatory.
There is the ability to import an image and the graph is set up to randomize the texture. You click on the Marble image where it states "none" and it will open up your file explorer to insert an image. If you need only colour there is a Tile colour Tab. Please Note there is a SWITCH to jump between the two.
The is quite a few adjustments, Grout Colour, joint width and bevel size of joint.
The next step is to add another switch and add the variation of tile patterns.
Comments and criticism welcome.
Tile Input Randomize texture or Coloured Tile Input.sbsar
  • 3 weeks later...
I've downloaded the trial of Substance Designer and played along with the tutorial for creating a first material. I've been using Genetica (no longer developed or supported) which is node-based, but SD is a significant step up in complexity and power. I took a stab at creating a Nichiha fiber cement material (Dimension Series, Ribbed Panel):
nichiha_ribbed_panel.sbs
Nichiha.calibz
321706927_Nichiha-DimensionSeries-RibbedPanel-Gunsmoke.thumb.jpg.3d4322adbfb6a7d550fc453cbe764d47.jpg1012329684_Nichiha-DimensionSeries-RibbedPanel-MotherofPearl.thumb.jpg.57f93fc542721eac3bc232a502329902.jpg
The first lesson I learned is that the Substance Designer PBR workflows don't exactly match the CA material definition, so it's necessary to tweak the SD outputs and CA inputs for best results. The second lesson is that improved materials are much more computationally expensive - optimizing the material maps is critical to improving raytrace performance and the performance of the material preview within the Material Definition dbx. Regardless, I welcome anything CA does that provides greater control over materials.
Dustin - can we assume that a Substance plugin is coming to Chief Architect? Is this possibility more than a pipe dream?
Hey gang, we just added the Wood_Builder_Beta.sbsar for you to be able to generate your own wood and wood flooring materials.
Parameter definitions have been added above and the file itself can be found in the original post (with the tile builder).  If you have any questions or issues, let me know and I'll make fixes/changes as needed.
Robert, we're always looking into ways to improve the user experience and a substance plug in would be just that.  Currently though, I have no news one way or another on a third party plug in.
  • Upvote 3
This is all fabulous stuff Dustin.  Thank you so much.  I do have one quick question though.  My spare time these days is pretty limited, but I do want to invest a bit more time in this.  Do you suspect this thread and the linked resources will be available indefinitely, or should I try to schedule some time sooner than later to download and install everything I need to.  I have a new computer coming here in the near future as well and don't want to have download and install things any more than I really have to.
Thanks again for your time!
