Renerabbitt Posted October 24, 2018 Share Posted October 24, 2018 Called up text support for this, someone I collaborate with has a different screen monitor and whenever he opens my plans and layouts the text gets screwed up, word wrapping occurs, text goes off of the page..very frustrating. Any bright ideas here would help. Tried cad blocking, tried un-checking auto width, no matter what the problem occurs. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 24, 2018 Share Posted October 24, 2018 Any Luck with a different font ? I think Chief Blueprint has some known issues that will hopefully be resolved in X11. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 24, 2018 Author Share Posted October 24, 2018 6 minutes ago, Chopsaw said: Any Luck with a different font ? I think Chief Blueprint has some know issues that will hopefully be resolved in X11. I've been using century gothic..suppose I can change all of my anno sets..ugh Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 25, 2018 Share Posted October 25, 2018 My solution to this is always just to group select text, open, and simply click okay. Annoying for sure, but that usually fixes it. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 25, 2018 Author Share Posted October 25, 2018 16 hours ago, Alaskan_Son said: My solution to this is always just to group select text, open, and simply click okay. Annoying for sure, but that usually fixes it. I'll give it a shot, just make a layer with everything off/locked but text Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 25, 2018 Share Posted October 25, 2018 21 minutes ago, Renerabbitt said: I'll give it a shot, just make a layer with everything off/locked but text Just use Match Properties. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 25, 2018 Author Share Posted October 25, 2018 21 minutes ago, Alaskan_Son said: Just use Match Properties. I don't follow? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 25, 2018 Share Posted October 25, 2018 Select a Text object, click Match Properties, check the box for Object type (Rich Text) and click okay to select all Rich Text objects that are displayed. You can also optionally activate the Rich Text tool and Shift Select everything in your view to group select only Rich Text or do the same thing with the Text tool selected to select both Text and Rich Text objects. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted October 25, 2018 Share Posted October 25, 2018 19 hours ago, Renerabbitt said: Called up text support for this, someone I collaborate with has a different screen monitor and whenever he opens my plans and layouts the text gets screwed up, word wrapping occurs, text goes off of the page..very frustrating. Rene, I've not run into this but am concerned since I know that some folks I deal with will have different settings. Wondering what res, size and what scale you are both using. Maybe post something? I'd like to try it. FWIW I use 3 monitors all with different resolution-1920 x 1080, 2560 x 1440, 1920 x 1200. It could be that on my end that works because I use a monitor manager which won't help you. IT may also be ALL are set to 100% scale. It's possible I had problems with different scale settings on each but have CRS so can't say. Link to comment Share on other sites More sharing options...
CElder Posted June 25, 2021 Share Posted June 25, 2021 @Renerabbitt - Did you ever find a solution to this? I'm having the same issue when I do work on my laptop at home then plug in to a larger monitor in the office. They are both set to 1920x1080 and 100% scale but it keeps happening and is very frustrating when I have to check my text boxes every time I re-open a file! I hadn't thought to do a Match Properties sweep to grab them all at the same time. I was going into each box separately and clicking ok so it would reset. Hoping for a better solution that will actually fix the problem if you have found one in the past few years! Link to comment Share on other sites More sharing options...
robdyck Posted June 25, 2021 Share Posted June 25, 2021 1 hour ago, CElder said: @Renerabbitt - Did you ever find a solution to this? I'm having the same issue when I do work on my laptop at home then plug in to a larger monitor in the office. They are both set to 1920x1080 and 100% scale but it keeps happening and is very frustrating when I have to check my text boxes every time I re-open a file! I hadn't thought to do a Match Properties sweep to grab them all at the same time. I was going into each box separately and clicking ok so it would reset. Hoping for a better solution that will actually fix the problem if you have found one in the past few years! I believe not using Auto Width or Auto Height also prevents that issue. 1 Link to comment Share on other sites More sharing options...
RCurby Posted October 28, 2024 Share Posted October 28, 2024 On 10/25/2018 at 1:34 PM, Alaskan_Son said: Select a Text object, click Match Properties, check the box for Object type (Rich Text) and click okay to select all Rich Text objects that are displayed. You can also optionally activate the Rich Text tool and Shift Select everything in your view to group select only Rich Text or do the same thing with the Text tool selected to select both Text and Rich Text objects. OMG! This is genius!!!! You have saved me HOURS of time!!! Thank you SO much!!! 1 Link to comment Share on other sites More sharing options...
