CARMELHILL Posted September 6, 2018 Share Posted September 6, 2018 Does anyone know how to change the size of the text your writing in the text entry field of the Standard Text Specification dialogue box? I mean the visible text your in the process of typing, not what goes onto the drawing. I know this was discussed once before when someone was changing to a newer monitor size, but I've searched the forum and can't find it. It's not in the Preferences. It always seems so small, especially when you're display resolution is up pretty high. See attached. Link to comment Share on other sites More sharing options...
glennw Posted September 6, 2018 Share Posted September 6, 2018 For plain text you can zoom the text in and out in the preview pane using the mouse wheel. I don't think you can change it in the text entry pane. You can also make the preview pane bigger if needed and zoom all. With Rich Text you can do it to the text itself with the % scrollbox. Use Rich Text instead of plain text? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2018 Share Posted September 6, 2018 On 9/6/2018 at 7:30 AM, glennw said: Use Rich Text instead of plain text? Expand Glenn, check Ed's previous posting which I think is the reason for the Standard Text. Link to comment Share on other sites More sharing options...
CARMELHILL Posted September 6, 2018 Author Share Posted September 6, 2018 On 9/6/2018 at 7:30 AM, glennw said: For plain text you can zoom the text in and out in the preview pane using the mouse wheel. I don't think you can change it in the text entry pane. You can also make the preview pane bigger if needed and zoom all. With Rich Text you can do it to the text itself with the % scrollbox. Use Rich Text instead of plain text? Expand That's not what I'm talking about. I know the right preview pane can be enlarged, but I'm talking about the text ENTRY area to the left. Check my video. On 9/6/2018 at 7:49 AM, Chopsaw said: Glenn, check Ed's previous posting which I think is the reason for the Standard Text. Expand On 9/6/2018 at 7:49 AM, Chopsaw said: Expand Your sort of right. I will be using this text more often. But the text entry dialogue box has always been too small. Link to comment Share on other sites More sharing options...
glennw Posted September 6, 2018 Share Posted September 6, 2018 Edward, There is a setting in Preferences to change the toolbar button size that requires a relaunch, but as far as I know that has nothing to do with the text size you are talking about. Link to comment Share on other sites More sharing options...
CARMELHILL Posted September 7, 2018 Author Share Posted September 7, 2018 Thanks Glenn. I must have read it on the Archicad User Forum when I was shopping around. Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2019 Share Posted February 11, 2019 Hmm. No solution yet? My eyes aren't getting any better as I get older. It's tough to see that text and I also need to make it to display larger. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 6:22 PM, robdyck said: Hmm. No solution yet? My eyes aren't getting any better as I get older. It's tough to see that text and I also need to make it to display larger. Expand Seems we have the same issue was just looking at this , and opened my Defaults>Text + markers>Text>1/4 Defaults and the text seemed Larger than it just had in Plan View, so I okayed back out and now the Text in a new Text Box seems larger too....not much but larger..... or maybe I am showing my age again M. Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2019 Share Posted February 11, 2019 I don't know of any place to control this. Seems like it'd be in "preferences"... Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 7:16 PM, robdyck said: I don't know of any place to control this. Seems like it'd be in "preferences"... Expand I have asked for User Control of the GUI in the Past, but we don't have it yet, some stuff is controlled by the Windows Icon Text Size , eg the Project and Library Browser Tree but it appears many Items are "Hard-coded". To change stuff in Windows 10 I use Advanced Font Changer as Windows no longer allows easy access to the Font and Size , it is in this Post from last year : https://chieftalk.chiefarchitect.com/topic/20793-update-text-programming/?do=findComment&comment=168932 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted February 11, 2019 Share Posted February 11, 2019 You can make everything larger in Windows if you have a hi-res monitor by right-clicking in the display desktop area, choosing Display Settings, go to custom scaling (Advanced Scaling Settings) and set to 125% or 150%, say. You will need to choose the option to sign out, to get this to go into effect. You MAY find this causes problems with text wrapping incorrectly initially, but not always. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 8:39 PM, Richard_Morrison said: You can make everything larger in Windows if you have a hi-res monitor by right-clicking in the display desktop area, choosing Display Settings, go to custom scaling (Advanced Scaling Settings) and set to 125% or 150%, say. You will need to choose the option to sign out, to get this to go into effect. You MAY find this causes problems with text wrapping incorrectly initially, but not always. Expand My monitor is 2K (2560x1440) , so Windows10 automatically scales it to 125% , and I then adjust things like Icon Size and Scrollbars with Advanced Font Changer.....(above) as I found 150% was just too big for everyday use...AFAIK at 4k Windows 10 should autoscale to 200% M. Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2019 Share Posted February 11, 2019 Interesting. Higher resolution monitors may be the answer then (more $...YAY). I did try re-scaling the font using Windows settings and everything in Chief ended up blurry, even after signing out and letting Windows try to fix the blurriness. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 8:47 PM, Kbird1 said: My monitor is 2K (2560x1440) , so Windows10 automatically scales it to 125% , and I then adjust things like Icon Size and Scrollbars with Advanced Font Changer.....(above) as I found 150% was just too big for everyday use...AFAIK at 4k Windows 10 should autoscale to 200% M. Expand On my 4K 43" monitor, it autoscales at 350%. However, the display scaling starts at the autoscale level, and adjusts it from there. If you wanted just a tad larger, you could use display scaling at 110%, and it would be 10% larger than the autoscaled version. At least, that's the way it works on my monitor. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 8:58 PM, robdyck said: Interesting. Higher resolution monitors may be the answer then (more $...YAY). I did try re-scaling the font using Windows settings and everything in Chief ended up blurry, even after signing out and letting Windows try to fix the blurriness. Expand Are you at FHD res? (1920x1080) the DISPLAY scaling should be 100% or 125% but I find it best to use ASFC (AFC) rather than using what is really like a magnifying glass but for Chief specifically using Richard's method above maybe the only way, as AFC can't change Chief GUI Text sizes, it only effects the Parts that use the Windows Explorer like Folder Trees as mentioned. PS I went from 23" FHD to 32" QHD monitors and wouldn't change back..... personally I need IPS or IPS like (VA/MVA) panels as my eyes don't TN based monitors (=headaches) but that is a personal consideration but generally IPS has better colour etc than TN too. M Link to comment Share on other sites More sharing options...
robdyck Posted February 11, 2019 Share Posted February 11, 2019 Just tried it again using Windows 10 Display settings. No blurriness this time, because I'm an idiot. I thought before that the toggle button for "Fix scaling for apps" was on but it wasn't. It did mess up the way some of my text was displaying in plan view but easily fixed. Some CAD symbols with text however needed to be adjusted. This is a true sign of aging...needing the font bigger and then not knowing how the computer settings work. Yikes! Thanks for the suggestions, Mick. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2019 Share Posted February 11, 2019 On 2/11/2019 at 9:35 PM, robdyck said: Just tried it again using Windows 10 Display settings. No blurriness this time, because I'm an idiot. I thought before that the toggle button for "Fix scaling for apps" was on but it wasn't. It did mess up the way some of my text was displaying in plan view but easily fixed. Some CAD symbols with text however needed to be adjusted. This is a true sign of aging...needing the font bigger and then not knowing how the computer settings work. Yikes! Thanks for the suggestions, Mick. Expand You know you are worth a nice new 32" 2K monitor ....just do it..... put the old ones either side for now..... it's how I did it at 1st too. Just had to buy a few pairs of new Glasses so that is my "spend" for the next wee while.... M. 1 Link to comment Share on other sites More sharing options...
