Bump Maps
stager386
My bigger question is how to make ray traces look their absolute best.  My walls end up looking sparkly. There are dark spots throughout, and materials aren't looking real.  I know I have to learn more about material definitions.
One video shows the wood floors looking realistic due to bump maps.  But there is nothing explaining what a bump map is, where it is, how to get it, and how to apply it.
Thoughts?
Bump maps are usually just a copy of the image texture assigned as a bump map on the "Properties" tab of a material. Bump maps can give a material greater 3D presence and sometimes they make a material look fake, so it is not a simple matter of assigning one to a texture and that is that, you will then need to Ray Trace to evaluate the change. Ray Tracing, in general, is a trial and error affair adjusting lighting and materials settings until you feel like the render is enhanced.
CA's documentation tends to lag behind on new features , so they are not always mentioned in the Manual or Help, Bump Maps are assigned on the Texture tab of the material's definition but for many many materials they are not supplied by CA , so you would need to make you own in Photoshop or Gimp or perhaps an online converter?
Dan does a great job of explaining the differences between bump and normal maps and how to use them in Chief in this video here:
https://www.chiefarchitect.com/videos/watch/10153/quick-tip-chevron-herringbone-materials-with-normal-maps.html
In this Knowledge Base article, you are shown how to apply a bump map to a material in Chief:
https://www.chiefarchitect.com/support/article/KB-01076/creating-etched-glass.html
In this article, I give a brief explanation on what bump and normal maps are, and how to create your own:
https://kcclemo.neocities.org/creating-height-and-normal-maps/
1 hour ago, stager386 said:
Here is my latest RT. See the specs on the red sofa? Lighting is odd.  Floor has no texture.
Do you have a Foundation and Roof Built ?  both are usually required for proper lighting to work in my experience.....
Are there Potlights (R.Cans) or added 3D lights in the Red Sofa Room?  , not sure why there is 4 light blotches otherwise.
lowering the roughness of the Floor material to 10-15% should give it some shine at least that works in PBR but the settings don't always translate, but make sure you are using the latest Updated X10 Material Libraries too ( Library>Catalog Update) CA older Wood textures don't work well in X10 and have all been now updated.
Thanks Kirk , are you aware of Awesome Bump ? it's a Free Open Source Bump Map Program I found recently on GitHub , latest version is 5.1 ,it is a portable Qt based program so nothing to install , just unzip the Folder. I'd be interested in what a 3D Artist has to say about it as it's not exactly my field of expertise.
https://github.com/kmkolasinski/AwesomeBump/releases/tag/Winx32v5.1
One Note about Awesome Bump , I found I had to Open the 3 Config files and change the Font Size to 12 to make it all more readable for me , not sure which one is controlling what so I changed them all ...The Author must have good eyes :) as it is set at 8.
Main folder : Config.ini
Configs Folder : gui.ini and 48_AwesomeBump.ini
Yes light cans in the room with the red sofa.
I don't normally build a roof and foundation when I am just doing the interior.  Should I?
The floor material def dialogue box doesn't allow me to change the roughness.
What is PBR?
Thank you!!
Yes, it's best practice to always have a roof and a foundation with a floor in your model, even for interior Ray Traces. Without these you can encounter what we call light bleed, it's when light from the exterior bleeds into the interior though wall ceiling and floor intersects. A foundation with a floor is very important if you are using the "Environment Lighting" in the Ray Trace DBX. Without the foundation and floor you can get speckles and unusually highlighting along baseboards and underneath furnishings.
If you could post your plan it would make resolving the sofa speckles much easier as we can check into the lighting and material settings to see what's going on.
PBR = Physical Based Rendering
I now use it exclusively as it is very fast and allows editing 'on the fly." But, I am not trying to produce EXACT renderings as to the time of day, GIS coordinates, and precise materials.
My job is to get enough information into the picture to make viewers like the space and see that their own 'stuff' will work within the space. My goal is to suggest how the space may be used, and possibly suggest a demographic or lifestyle.
Ray Tracing still has some benefits. I'm just glad that PBR is in CA X10, and that it's good enough for my work.
Yes, I've played around with it from time to time.
I still check in on it to see how it's coming. It's a very promising alternative to programs like Crazy Bump.
Personally, I use a more manual approach to creating my various maps in GIMP and Blender. I just wanted the information in my article to be usable with as little setup/learning as possible to get people started.
Someday, I would like to use substance painter which generates textures procedurally along with all the maps needed for the texture, but, I haven't been able to justify the expense yet.
Thanks for the reply...... I was following your Tutorial but could not equate the Histogram Slider in Gimp/PS to something Similar in Awesome Bump but I haven't played with it much yet.
What is PBR?
This is CA's Video on PBR ,
https://www.chiefarchitect.com/videos/watch/2412/3d-rendering-features-added-in-x10.html
They use the Settings some of us discovered while trying to fix issues in the Earlier versions of X10 , these can be set in your Camera defaults , the Use Enhanced lighting and setting max lights to 100 is important otherwise you can get White-outs or Black-outs in the PBR Camera. The Who thread is on PBR when you have time to look at it...
1 hour ago, Cheryl_C_Crane said:
I used PBR and adjusted the lights (cans are Off) to 100. I didn't have some of your textures, like the rugs, red sofa, etc. But, this should give you an idea
25 minutes ago, Kbird1 said:
Do a File>Backup Entire Plan
it will create a Zip file with all the Textures and the plan in it that you can attach instead since it looks like you have Custom textures....
I don't back up my own files. I have a service do that.  If I try and do what you've suggested, it zips up way too many files, not just this the one associated with this plan.
Here's a Ray Trace with the settings as outlined below. Ran 30 passes, 19 min.
5b7b47a7ebd51_Example_with_decor_Abode_RayTrace.thumb.jpg.106ddedd1546d53a080794314d16d84c.jpg
Changes
Sun Intensity = 1,000 Lux, Changed direction = Tilt -32, Direction 258.6
3D Lights = 100 lumen, height off of floor = 55"
Two Floor Lamps = 400 lumen
Auto Built Roof, Foundation with Floor
Added Bump Map to Floor (just used texture file) and changed to Polished
Environment Lighting = Off
Photon Mapping = On
Direct Sun =50
Ambient Occlusion = min 0, Max 1.5
Image Properties = 50,40,25,51,48,75,40
It will put everything in the plan in the Zip file , all the materials , images, pdfs etc , anything related to the plan so Others will see what you see when they open it.
Here is PBR, lights adjusted to 100 and cans off.  Why does it look like this?
