RaquelPorlamar Posted August 14, 2018 Share Posted August 14, 2018 Hi Everyone, I am new here and relatively new using CA... I'm trying to create a half moon counter that gets slimmer toward the bottom. Height needs to be around the 36", width at top 40" and narrowing to 30 when reaching the floor. I hope you have the patience to explain step by step. I tried CAD, Curved half wall, bowed front counter and couldn't figure out how to completely manipulate the edges to make what I want. see attached example - photos from madeinchine.com Thank you all in advance Link to comment Share on other sites More sharing options...
rlackore Posted August 14, 2018 Share Posted August 14, 2018 1. Draw a truncated pyramid as so: This will be the curved counter piece. 2. Draw a cylinder in the center of the pyramid. Make it taller than the pyramid. This will be subtracted from the pyramid: 3. Boolean subtract the cylinder from the cone: 4. Draw a box, larger than the pyramid, and do another boolean subtraction: 5. In ortho view, grab the rotate handle and rotate the shape 180 degrees to the proper orientation: 6. Now position the shape relative to the counter: What this technique can't give you are the rounded edges on the curved shape, so a better alternative would be to create the shape in another program, such as Sketchup. That said, someone else on the forum may have a better method. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted August 14, 2018 Share Posted August 14, 2018 Pretty much the same thing. I used cad lines to determine the angle and the height if it were a complete cone (disconnect the lines or don't allow them to connect to begin with), drew a cone, copied and pasted in place, changed the diameter of the second cone and changed it's materials, subtracted small cone from large one, then added boxes to use to cut it in half and shorten it. When done flip it over in a 3D view If it's less than half a circle it's harder to figure out-draw cad in plan first to get the diameters, then in elevation. Link to comment Share on other sites More sharing options...
rlackore Posted August 14, 2018 Share Posted August 14, 2018 Even easier: 1. Draw a CAD profile and save it to your library: 2. Draw an arc and convert it to a molding polyline, then add the profile: 3. Position it within the cabinets: This method provides the lovely rounded edges on the curved piece. 2 Link to comment Share on other sites More sharing options...
MarkMc Posted August 14, 2018 Share Posted August 14, 2018 1 hour ago, rlackore said: Even easier: Very Nice Link to comment Share on other sites More sharing options...
Chopsaw Posted August 14, 2018 Share Posted August 14, 2018 I suspect the component you need really should have a piece removed that would interfere with the cabinets. So to combine the best of both of Robert's ideas I would start with an accurate CAD profile drawn in elevation view and snap a face into that CAD profile and use the Revolve Object tool to rotate it 180°. Then you have a solid that can be further refined using boolean operations. Such as Solid Subtraction to cut out the unwanted underside. Link to comment Share on other sites More sharing options...
RaquelPorlamar Posted August 15, 2018 Author Share Posted August 15, 2018 Hello Gentlemen, thank you. I guess I should have mentioned I have the hone interiors edition rather than the premier package. Still working on this Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 15, 2018 Share Posted August 15, 2018 22 hours ago, Chopsaw said: I would start with an accurate CAD profile drawn in elevation view and snap a face into that CAD profile and rotate it 180° I think you probably meant revolve right? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 15, 2018 Share Posted August 15, 2018 31 minutes ago, RaquelPorlamar said: I have the home interiors edition rather than the premier package Unfortunately HDI can not do any of the above , not even HD Pro does , so an inverted Cone maybe your only Option? But HDI can not cut it.... Unless one of the kind Gentlemen here exports his model for you ? The Home titles have their own Forum called HomeTalk over here : https://hometalk.chiefarchitect.com/?_fromLogin=1 Same Username and Password over there......someone may have a workaround over there? It's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. 1 Link to comment Share on other sites More sharing options...
RaquelPorlamar Posted August 15, 2018 Author Share Posted August 15, 2018 Thank you gentlemen, I am way lost I see. But all good, I am considering converting to the latest in Premier. In the meantime I will go ahead and post under home interiors. Thank you for taking the time, I'll be around once I upgrade Ciao Link to comment Share on other sites More sharing options...
MarkMc Posted August 15, 2018 Share Posted August 15, 2018 14 minutes ago, RaquelPorlamar said: Thank you gentlemen, I am way lost I see. But all good, I am considering converting to the latest in Premier. In the meantime I will go ahead and post under home interiors. Thank you for taking the time, I'll be around once I upgrade Ciao Here is symbol 40" at top, 30 bottom, 36 high, Not sure that is correct from photos but matches your dimensions. Cup.calibz Link to comment Share on other sites More sharing options...
Chopsaw Posted August 15, 2018 Share Posted August 15, 2018 1 hour ago, Alaskan_Son said: I think you probably meant revolve right? Yes. Thank You. See Above for edit. Link to comment Share on other sites More sharing options...
rlackore Posted August 16, 2018 Share Posted August 16, 2018 Raquel, maybe you're not longer monitoring this thread, but if you are, I recommend learning Sketchup. It's become a critical part of my Chief workflow, has many available plugins that make things easier, and can create your cabinet piece for import into Chief as a Symbol: caffevero.skp Link to comment Share on other sites More sharing options...
RaquelPorlamar Posted August 16, 2018 Author Share Posted August 16, 2018 22 minutes ago, rlackore said: Raquel, maybe you're not longer monitoring this thread, but if you are, I recommend learning Sketchup. It's become a critical part of my Chief workflow, has many available plugins that make things easier, and can create your cabinet piece for import into Chief as a Symbol: caffevero.skp Hi Robert, I do get the email notifications. This looks great. I do want to get into the sketchup too, when I have more time that is... this looks great. I am tempted to ask you to send it to me. I haven't used sketchup for CA yet. Link to comment Share on other sites More sharing options...
