ED-209 Posted July 31, 2018 Share Posted July 31, 2018 Hi, How do I hide the horizontal line that's showing where the upper floor is in the "line drawing view"? I've added an image so you can see what I mean. Thanks. Link to comment Share on other sites More sharing options...
kMoquin Posted July 31, 2018 Share Posted July 31, 2018 Confirm your walls are aligned floor to floor. Are there different wall types on the two floors or are they the same? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 31, 2018 Share Posted July 31, 2018 When you print to PDF, those lines usually go away, or turn off floor joists in that camera view. Link to comment Share on other sites More sharing options...
HumbleChief Posted July 31, 2018 Share Posted July 31, 2018 I've chased those lines for many, many years with Chief. Sometimes they are very easy to resolve with aligning floors, matching materials etc.. Other times nothing helps and I've learned to live with them. Link to comment Share on other sites More sharing options...
glennw Posted August 1, 2018 Share Posted August 1, 2018 I usually find that occurs as a result of the floor platform building through the walls, commonly caused by either the main wall layer or the "build platform to" layer being designated incorrectly. Link to comment Share on other sites More sharing options...
ED-209 Posted August 1, 2018 Author Share Posted August 1, 2018 19 hours ago, DRAWZILLA said: When you print to PDF, those lines usually go away, or turn off floor joists in that camera view. How do I turn those off? Link to comment Share on other sites More sharing options...
ED-209 Posted August 1, 2018 Author Share Posted August 1, 2018 11 hours ago, glennw said: I usually find that occurs as a result of the floor platform building through the walls, commonly caused by either the main wall layer or the "build platform to" layer being designated incorrectly. It's just a standard house that I want to turn into a symbol, in order to drop onto to various site plans. I just press the "build new floor" button when I've built the walls, so it shouldn't have different values. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 1, 2018 Share Posted August 1, 2018 3 hours ago, ED-209 said: It's just a standard house that I want to turn into a symbol, in order to drop onto to various site plans. I just press the "build new floor" button when I've built the walls, so it shouldn't have different values. I find it is often just the viwing angle causing it , rotate the model 10-15° and they are gone ....but not always.... 3 hours ago, ED-209 said: How do I turn those off? In Active Layer Display Options (ALDO) , i usually have it enable and on a 2nd monitor so I can easily click layers on and off or lock them etc. You haven't done your signature , so no idea what version you have , so I can't tell you how to access it.... I also found it older versions this effect was worse if I started with an Orthographic camera compared to a Perspective Camera M. Link to comment Share on other sites More sharing options...
