Doug_N Posted July 10, 2018 Share Posted July 10, 2018 Does anyone know if this option is available in CA X10? And if so, where did it go? Link to comment Share on other sites More sharing options...
Doug_N Posted July 11, 2018 Author Share Posted July 11, 2018 Hi Eric, Thanks for your reply, but I was referring specifically to the option by the red arrow. It was there in CA x9 but not there in CA x10. The image is from version x9 In version x10 it looks like this Link to comment Share on other sites More sharing options...
CharlesVolz Posted July 11, 2018 Share Posted July 11, 2018 Here or use the icon hot button. EDIT: Sorry about that. I thought from your 1st post that you were just trying to display arc centers and ends... I need some sleep... Link to comment Share on other sites More sharing options...
Doug_N Posted July 11, 2018 Author Share Posted July 11, 2018 Charles, I am not up to my usual game I suppose but I don't understand how that is related to the question. Link to comment Share on other sites More sharing options...
rlackore Posted July 11, 2018 Share Posted July 11, 2018 As Eric showed, this setting can be found either when you build the framing, or within the Default Settings>Framing Defaults>Plan Display tab: Link to comment Share on other sites More sharing options...
glennw Posted July 11, 2018 Share Posted July 11, 2018 Robert, Doesn't that only apply to the display in plan view - not a cross section view? After all, it is on the Plan Display panel. 1 Link to comment Share on other sites More sharing options...
rlackore Posted July 11, 2018 Share Posted July 11, 2018 2 hours ago, glennw said: Robert, Doesn't that only apply to the display in plan view - not a cross section view? The OP didn't ask about cross-section views - the setting he referred to controls the appearance of framing members in Plan. AFAIK, you can't control the fill color of a framing member in a Cross Section view: cut members will have a solid white fill, and members in elevation will be filled with the Material color. Link to comment Share on other sites More sharing options...
HumbleChief Posted July 11, 2018 Share Posted July 11, 2018 Thanks for this post. I don't use that often but I'm sure I would have looked in the old spot and posted the same question. Link to comment Share on other sites More sharing options...
