Designer100 Posted June 19, 2018 Share Posted June 19, 2018 How do I place a flood light on a exterior column or exterior soffit? Aalso placing a electrical outlet on a column. I have made a small retangle wall in past to do it. Any suggestion? this is something cheiv developers need to work on. It says walls or cabinets! Ther should be a simple solution. Link to comment Share on other sites More sharing options...
tommy1 Posted June 19, 2018 Share Posted June 19, 2018 I'll call you. 2 Link to comment Share on other sites More sharing options...
tommy1 Posted June 19, 2018 Share Posted June 19, 2018 Room dividers really aren't necessary. They've made this a lot easier to do in X10. 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 19, 2018 Share Posted June 19, 2018 you can also just place a cad block from the cad block lib. Link to comment Share on other sites More sharing options...
johnny Posted June 19, 2018 Share Posted June 19, 2018 6 hours ago, Designer100 said: How do I place a flood light on a exterior column or exterior soffit? Aalso placing a electrical outlet on a column. I have made a small retangle wall in past to do it. Any suggestion? this is something cheiv developers need to work on. It says walls or cabinets! Ther should be a simple solution. I make a lot of my columns from Cabinets. I would suggest that, very easy and lots of control. Link to comment Share on other sites More sharing options...
KirkClemons Posted June 20, 2018 Share Posted June 20, 2018 This article outlines the process in more detail:https://www.chiefarchitect.com/support/article/KB-00478/modifying-a-light-for-placement-on-a-stair-or-pier-piling.html Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 20, 2018 Share Posted June 20, 2018 In addition to the above, it can also be as simple as just placing the fixture onto a wall, selecting it, clicking Open Symbol>Options, changing it to Floor Mounted, and then moving it to wherever you want it. 1 Link to comment Share on other sites More sharing options...
tommy1 Posted June 20, 2018 Share Posted June 20, 2018 40 minutes ago, Alaskan_Son said: In addition to the above, it can also be as simple as just placing the fixture onto a wall, selecting it, clicking Open Symbol>Options, changing it to Floor Mounted, and then moving it to wherever you want it. That's the ticket and is what I do. Much easier and faster. No walls. If the symbol is set for wall mount, just place it on a wall and do as Michael said. Link to comment Share on other sites More sharing options...
tommy1 Posted June 20, 2018 Share Posted June 20, 2018 BTW, something else I do. After it's placed on the column, slab, solid or whatever so it looks good in plan view, I then open that symbol and set all the origins to "0" so the bounding box is good. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 20, 2018 Share Posted June 20, 2018 45 minutes ago, tommy1 said: BTW, something else I do. After it's placed on the column, slab, solid or whatever so it looks good in plan view, I then open that symbol and set all the origins to "0" so the bounding box is good. This really kind of depends on the symbol of course and on what you are trying to accomplish. If for example a symbol has the junction box included, it would probably be best to leave a y offset; and if you would like to place the height based on the center of fixture or j-box then you might also want to leave a Z offset as well. Regardless of your intentions though, you would likely want to at least double check the offsets and adjust as/if necessary. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 20, 2018 Share Posted June 20, 2018 Great tips you guys thanks... Link to comment Share on other sites More sharing options...
Designer100 Posted October 3, 2018 Author Share Posted October 3, 2018 Awsome suggestions Link to comment Share on other sites More sharing options...
