dshall Posted May 23, 2018 Share Posted May 23, 2018 Would somebody please do me a favor and import ACAD file and see if it is to scale. When I import, it does not come in a proper scale. Thanks, harris 2018 0523 bluff setback11-10035-p3.dwg 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 23, 2018 Share Posted May 23, 2018 No they pulled that trick that architects usually do when passing on drawings. It is over scaled by about 5% Transform and Replicate and call them and tell them they are bad. Link to comment Share on other sites More sharing options...
chief58 Posted May 23, 2018 Share Posted May 23, 2018 doesn't scale for me either Link to comment Share on other sites More sharing options...
MarkMc Posted May 23, 2018 Share Posted May 23, 2018 Yes scale is off Only checked the one length, did not check for distortion. Adjusted and attached. Adjusted.dwg Link to comment Share on other sites More sharing options...
Chopsaw Posted May 23, 2018 Share Posted May 23, 2018 Wow is that ever dirty... In the opposite corner of where the scale is located there is a note: "Locations and dimensions are approximate." NOT COOL !! Link to comment Share on other sites More sharing options...
dshall Posted May 23, 2018 Author Share Posted May 23, 2018 Thanks guys for the help and thank you Mark for the adjustment. So weird, they wanted me to be able to import some of the lines into my drawing. It was probably done by accident. Thanks again, all is well now. 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 23, 2018 Share Posted May 23, 2018 26 minutes ago, Chopsaw said: No they pulled that trick that architects usually do when passing on drawings. Well, that new "kinder and gentler" forum concept didn't last long, did it? Link to comment Share on other sites More sharing options...
rlackore Posted May 23, 2018 Share Posted May 23, 2018 I opened the file in ACAD, and it's pretty messed up. The lot lines are drawn about 5% larger than labeled, but who can trust lot lines? More telling is the graphical scale, which is drawn 4.8368% longer than labeled. The 30' right-of-way centerline measures 29' 8". So, going by the lot lines and the graphical scale, everything needs to shrink; going by the right-of-way, everything needs to grow. Good luck. Link to comment Share on other sites More sharing options...
