RobUSMC Posted May 5, 2018 Share Posted May 5, 2018 I like to use a base cabinet for a tub deck because you can easily drop a tub into it just like the sink with it automatically cutting the hole in the countertop. Its a big time saver and can adjust height, finish and door style quickly. However as shown in the rendering, when there needs to be more than one cabinet to create the shape needed for the deck it can cause issues. This shows the individual side walls of the cabinets running thru the tub. Short of using a PS for the beck the another for the top and cutting a hole for the tub then applying doors to the face does anyone else have a good way to make this happen? Thanks Link to comment Share on other sites More sharing options...
chief58 Posted May 5, 2018 Share Posted May 5, 2018 can you make the protruding cabinet lets say 6" or so narrower Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 5, 2018 Share Posted May 5, 2018 On 5/5/2018 at 4:27 PM, RobUSMC said: I like to use a base cabinet for a tub deck because you can easily drop a tub into it just like the sink with it automatically cutting the hole in the countertop. Its a big time saver and can adjust height, finish and door style quickly. However as shown in the rendering, when there needs to be more than one cabinet to create the shape needed for the deck it can cause issues. This shows the individual side walls of the cabinets running thru the tub. Short of using a PS for the beck the another for the top and cutting a hole for the tub then applying doors to the face does anyone else have a good way to make this happen? Thanks Expand Off the top of my head I would guess that checking “cabinet filler” in the .dbx might get you what you want...just can’t remember if that retains paneling Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 5, 2018 Share Posted May 5, 2018 I draw a poly line then convert it to a countertop, you can have any shape you want, just make it as deep as your tub. The tub will also insert into it. Link to comment Share on other sites More sharing options...
RobUSMC Posted May 5, 2018 Author Share Posted May 5, 2018 Chief... That would effect the countertop and having a single door on the front of the clipped corner the correct size Link to comment Share on other sites More sharing options...
RobUSMC Posted May 5, 2018 Author Share Posted May 5, 2018 Perry. I have used the PS method alot and added separate doors to the face. I was looking to see if a quicker way was out there. It doesn't take a long time but when I have 16 projects going on even a savings of 10 minutes is huge Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 5, 2018 Share Posted May 5, 2018 I'm not using a PS, I'm using a countertop and There isn't mush storage space for any doors to use ,so I just use a tile face. very quick for me. The access can be from the outside or another wall. Link to comment Share on other sites More sharing options...
RobUSMC Posted May 5, 2018 Author Share Posted May 5, 2018 OK I see what you do. I always like to have all the plumbing accessible under the tub for inspection or repair and is the reason for the door fronts. We build the tub deck and apply a cabinet face frame and doors to the front Link to comment Share on other sites More sharing options...
MarkMc Posted May 5, 2018 Share Posted May 5, 2018 Change separations to zero, use blank area to create reveals, set sides and back to openings as needed, usually toe height at zero. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted May 5, 2018 Share Posted May 5, 2018 I been doing as Eric and Perry suggested using a countertop, it works out perfectly every time. 1 Link to comment Share on other sites More sharing options...
