10eighty Posted April 5, 2018 Share Posted April 5, 2018 Hey guys, I like printing my site plans on 8.5 x 11 paper. Is it possible to add an 8.5 x 11 sheet to my layout file? I have a hell of a time printing letter size to scale. Does anybody have any advice? Cheers, Randy Link to comment Share on other sites More sharing options...
lbuttery Posted April 5, 2018 Share Posted April 5, 2018 Randy: if the settings are done properly any size paper should be to scale one method I use for paper size is to draw on 18 x 24 for 1/4" scale with a border giving 17 x 22 then if needed I can print at 50% and it fits nicely on 8.5 x 11 for 1/8" scale same with 24 x 36 with a border for 22 x 34 for 1/4" scale which gives 11 x 17 at 50% for 1/8" scale Lew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 5, 2018 Share Posted April 5, 2018 You can only have one sheet size in a Layout, but you can have more than one Layout for a project. You are just limited to having only on open at a time - without some special gymnastics which I don't recommend. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 6, 2018 Share Posted April 6, 2018 On 4/5/2018 at 2:02 PM, Joe_Carrick said: You can only have one sheet size in a Layout, but you can have more than one Layout for a project. You are just limited to having only on open at a time - without some special gymnastics which I don't recommend. I thought I read recently here that you could have multiple Sheets sizes setup in Layout and then Print to whichever you needed ? Maybe I am not remembering that correctly ? M. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 6, 2018 Share Posted April 6, 2018 18 minutes ago, Kbird1 said: I thought I read recently here that you could have multiple Sheets sizes setup in Layout and then Print to whichever you needed ? Yes you can have multiples but you then need to switch between sheet sizes and only one sheet size can be printed at any one time. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 6, 2018 Share Posted April 6, 2018 7 hours ago, Chopsaw said: Yes you can have multiples but you then need to switch between sheet sizes and only one sheet size can be printed at any one time. And you have to switch the Annoset and Layer Set at the same time. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 7, 2018 Share Posted April 7, 2018 Thanks guys , I finally found the Thread which I had read about this in and The video Scott made a about it , I had not thought about using Layersets and Anno Sets in Layout to do this, I use them in Plan and have always just sent to the layout size I need. https://chieftalk.chiefarchitect.com/topic/17201-apply-new-layout-sheet/?tab=comments#comment-144532 Link to comment Share on other sites More sharing options...
