wjmdes Posted February 25, 2018 Share Posted February 25, 2018 I have been trying to find anything that is causing this for several hours. Turned everything on, re-framed everything, etc., but this upside down gable will not go away. Any ideas? 18-1002 647 John Wesley.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted February 25, 2018 Share Posted February 25, 2018 I saw this Reported in Beta , but don't remember the Fix off the top of my head.....I will try and look later if you don't get a Fix from someone else there is an error of extra Trusses being generated too in some Plans that Michael ( @Alaskan_Son ) found too Link to comment Share on other sites More sharing options...
wjmdes Posted February 25, 2018 Author Share Posted February 25, 2018 If I use edit area (all floors), copy and paste in place to a new plan, will it copy everything? Or will I have issues? Also, thanks, I spent toooo much time on that today!! Link to comment Share on other sites More sharing options...
glennw Posted February 25, 2018 Share Posted February 25, 2018 It is an Attic wall on the Attic floor level. Is the gable at the front of the porch open, or is there meant to be a gable wall there? You will need either a wall or a collar tie of some sort there to stop the gable roof from spreading. If you want to get rid of the framing, go up to the Attic level and delete that wall. I have no idea why it is building inverted like that. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2018 Share Posted February 26, 2018 I agree with Glenn, I occasionally see this and it is usually caused by an attic wall at the top level. Delete the stray wall and all is well. 1 Link to comment Share on other sites More sharing options...
wjmdes Posted February 26, 2018 Author Share Posted February 26, 2018 7 minutes ago, dshall said: Delete the stray wall and all is well. I spent several hours looking for anything, turning all layers on in every view and nothing I could find. I sent to support this AM. 18 hours ago, Kbird1 said: I saw this Reported in Beta , but don't remember the Fix off the top of my head.....I will try and look later if you don't get a Fix from someone else there is an error of extra Trusses being generated too in some Plans that Michael ( @Alaskan_Son ) found too I will post here the solution when I get it (unless it was something stoopid on my part) Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2018 Share Posted February 26, 2018 56 minutes ago, wjmdes said: I spent several hours looking for anything, turning all layers on in every view and nothing I could find. I sent to support this AM. I will post here the solution when I get it (unless it was something stoopid on my part) I tried finding that thread but couldn't, maybe it was on the Beta Forum? but is definitely not the 1st report of this.... M. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2018 Share Posted February 26, 2018 1 hour ago, wjmdes said: I spent several hours looking for anything, turning all layers on in every view and nothing I could find...... I found it in about 3.46 seconds. 2 Link to comment Share on other sites More sharing options...
wjmdes Posted February 26, 2018 Author Share Posted February 26, 2018 8 minutes ago, dshall said: I found it in about 3.46 seconds I don't like you anymore! No idea why I could not find it, any idea why it was upside down? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2018 Share Posted February 26, 2018 1 minute ago, wjmdes said: I don't like you anymore! It helps having 20+ years "Fixing" Chief Weirdness behind your belt there's a reason for Scott's YouTube Channel.... M. Link to comment Share on other sites More sharing options...
wjmdes Posted February 26, 2018 Author Share Posted February 26, 2018 1 minute ago, Kbird1 said: It helps having 20+ years "Fixing" Chief Weirdness behind your belt there's a reason for Scott's YouTube Channel... I have learned quite bit from his videos so his help is appreciated!! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 26, 2018 Share Posted February 26, 2018 11 minutes ago, wjmdes said: I have learned quite bit from his videos so his help is appreciated!! Me too actually ... I believe He is on Hiatus though, at least I haven't seen any reports on new videos of late... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2018 Share Posted February 26, 2018 I have seen this many times and its always an errant attic wall, Scott is correct. Link to comment Share on other sites More sharing options...
wjmdes Posted February 28, 2018 Author Share Posted February 28, 2018 Well apparently there are some issues with this Quote Hello William,Thank you for contacting Technical Support.I have sent your plan to our developers for review. For now, however, you can manually delete that wall framing from a framing overview.Kirk ClemonsTechnical Support Analyst Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 28, 2018 Share Posted February 28, 2018 I would delete all existing attic walls and re-do them Link to comment Share on other sites More sharing options...
wjmdes Posted February 28, 2018 Author Share Posted February 28, 2018 11 minutes ago, DRAWZILLA said: I would delete all existing attic walls and re-do them I have fixed the problem, but apparently they did find an issue with it framing an attic wall upside down. Link to comment Share on other sites More sharing options...
