ACADuser
Transparent wall?
I do these for the contractor & framer https://sketchfab.com/models/dbc6c399f0114a79a15549b540d6c65e
But I would like to add a semi transparent wall in the form of a p-solid on the long wall that separated this unit from the others.
How would you go about making it transparent like the 85% fill on plan view closed poly lines?
I would like to create a psolid that occupied the same space as the CMU wall but on a layer that is visible in 3D Framing view.
Thanks
Thanks
Alan,  You should be able to do that just by assigning the material to the p-solid and adjusting the transparency.
So draw a psolid over the CMU wall & make it glass? I'll give that a try.
That turned out pretty good.  https://skfb.ly/6v9tS
I used grey glass to mimic the block wall but made it more transparent.
Cranked up the contrast & sharpness to make clear clean lines.
Thanks
That looks great Alan,  also seems like sketchfab has improved their rendering quality since I checked it out last.  Thanks for posting.
Alan,
What's the process you followed to get your CA out to Scketchfab?
EXPORT TO DAE FILE TYPE.
I Create a sub folder, 3D, then export while in the camera view.
I then zip the dae file & folder Chief created.  Sketchfab will upload the zip file.
I post process the 3D settings for lighting & tome mapping.
Alan,
Thanks for the pointer.  I gave Sketchfab a try, but my results looked more like a post nuclear blast.  I acknowledge this is not CA related, but perhaps via a PM you could explain how you "post process the 3D settings for lighting & tome mapping".
Clive ( @renosud ) was explaining in the Mystery Materials Thread that that happens on SketchFab when you have too many materials for SketchFab to handle in the file ...ie over 100 but I don't know SketchFab myself to help much, check out his Post.....
Mick,
Thanks.  100 textures sounds like a major restriction.  Back to the viewer I guess.
SketchFab has a limit of 100 materials.  I solve the problem by eliminating any furniture, only use one or two types of trees/plants or none at all.  Go to your 3DS sub file and check the number of materials there before you zip the file.
19 minutes ago, cv2702 said:
Mick,
He got his Model working and it looked pretty good..... he just had to go through and edit his materials more carefully as Chief loads 60+ default ones I think he said ?.
SketchFab is apparently considering raising the Limit for free Users since more small Architecture and Design Firms are a starting to use it...
    27478
    Oilersfan20
    Oilersfan20
