EmmaCox
Sketchup model to Chief object x9
I am trying to import sketchup furniture from Teknion. They have a "resources" page where you can download Sketchup models. Once you download the Sketchup model, you can import it into Chief. The first one I tried worked, but now I am getting the attached pop up. Also, is there any way the blocks can be exploded? They seem to be furniture layouts and not single furniture components.
Thanks in advanced.
Was the one that failed a 2018 version ?   It is a bit of work but you can use the delete surface tool and remove surfaces from the grouping and create a new smaller symbol.
When import from 3d warehouse I have to import older skp versions.
Usually 2015 works
Here is a link to some links of Michael's on the subject.
Do you know how to download older 2015 version? I can't seem to figure it out for the Teknion furniture.
I will take a look at Michael's links tonight, thanks!
Yes there is usually a choice of versions in the drop down menu when downloading from the 3D Wharehouse.
*** Incorrect info see next two posts....
Teknion Furniture is all SketchUp Version 2018 by the looks , at least the models I tried , none would open in Sketchup Make 2017.....
if you click the image of the furniture piece, it opens another window and the download button opens the dropdown for different Years Files.
2017 version files work with X9 BTW
they do open in the SketchUp Free App  , which is now Web Browser Based  but unlike Sketchup Free of Old I see no way to "Save As" > 2015 Version as you used to be able to do.
I may have missed something  , this is the App Web Interface where you can sign in with Gmail etc.          https://app.sketchup.com
Ask Teknion to make a 2017 Version Full Chief Library perhaps....
19 minutes ago, Chopsaw said:
Sorry the ones I randomly checked were available back to 2014.
https://3dwarehouse.sketchup.com/collection.html?id=ua09415ea-83e3-4e71-9332-186eb1c2c3da
I see that  ... I was looking at the Resources Library on Teknion's Website , that Emma referred too , and the ones I tried were all 2018 I guess, according to Sketchup 2017... maybe I was unlucky?
EDIT :  I now see the issue I think , Emma did what I did and just clicked the download icon , which gives you the latest version automatically , without opening the dropdown, if you click the image of the furniture piece, it opens another window and the download button opens the dropdown for different Years Files.
2017 version files work with X9 BTW.
Mick.
Thank you all for your help.
I have finally figured it out. Instead of downloading from the Teknion website (wouldn't let me pick a year of Sketch up to Download), i went and found it on the 3D Warehouse.
Does anyone know how to explode an imported Sketch up file that i brought into Chief Architect?
thanks,
Angela
Unless there is something I am not aware of you can't explode and edit symbols like you can arch blocks.
thanks,
Angela
Angela, Please see the link I posted for Emma in post #4
Post a plan with the symbol in it describing how you would like it modified and I'll see if I can make you a quick video.
You need to open file in sketch up In order to edit it... Then save it  but in an older version of SU to be sure it will open in chief.
Thanks guys (sorry on the delayed response) , my sister Angela figured it out! Appreciate all the help :)
    27499
    Bren0625
    Bren0625
  • Similar Content
    • By Designer100
      The attached pergolia remodeling I am trying to copy and paste stone column, with cap and 8" wood posts to another plan of same buliding of site plan. I even blocked the column and it only pastes the stone base , not the cap nor the 8 in posts. I would also like to
      past the pergolia framing etc. to the new plan. but mainly the full columns now. any suggestions.
      Pergola.zip
      site plan.zip
    • By Ange822
      Hi there,
      I am new to this ChiefTalk / Forum but i need help.
      I am trying to Import a 3D Sketch-up object from the 3D warehouse into chief. It is a Teknion office product.
      When i go to File - Import - Import 3D symbol - attach the document, i get the attached pop - up.
      Any idea's what the issue could be?
      I am using X9.
      thanks,
      Angela
    • By Ridge_Runner
      Is there a way to move all of the CAD items on an existing layer to another layer for the entire plan? I am cleaning up some of my layers to simply the list. Over the years my layers have grown and I have some CAD blocks with lines on an old layer that I would like to move to a newer layer and then delete the old layer. For instance: I would like to move all of the CAD on an old layer named "CAD line size 25" over to a newer layer named "CAD 25." If it could be done then I could delete the old layers I no longer use. I have tried but have not been successful without exploding a block first; that would be a nightmare for all of the CAD blocks I have accumulated. But maybe I am missing something or it is so simple I am overthinking it. It would also be helpful if there was a way to determine which blocks use a certain layer. If so then only those blocks would have to be redone. Thanks in advance.
    • By SNestor
      I'm attempting to make my own shelf and rod symbol.  The symbol is easy enough...but, the CAD block is another story.  I want line that represents the pole to be a dashed line...representing that it is underneath the shelf.  I've tried just about every thing I can thing of...and no matter what I do the line in the CAD block is always solid.
      When I made the symbol I called it a "Fixture"...is this the problem?  When I place the symbol into a plan...does the new plan assign the layer to the symbol...like a CAD block?  Or does it retain the layers it was created with?
      Attached are some pics...
      this is what I'm trying to achieve...
    • By DaveCoyleJr
      I was wondering if it was possible to somehow import an entire SketchUp full home model into chief and then break it down into a floor plan? I know that I can take plans and pdf trace them, however, I have a full model already done, I'd like to just use as my base. Is this even possible? I have the SketchUp DWG file as well if that helps.
