Underside of a roof plane
mtldesigns
Good evening fellow CA users.
Got a nice gig for a Florida house that required rafter tails.  That part was easy, but wondering how to put the painted board on the underside?  I added thickness via Roof Surface Definition but it creates under whole roof plane.  Just watched a couple training vids. too, and nothing noting this part.  I checked and unchecked a lot of buttons too on the roof dbx.. so I am thinking its a combination?
That's what I think Eric was mentioning, and I thought the same thing too, two planes, same ptich.  I'm going to try a couple of these other options you all mentioned than the one I did, and see how it goes.  Maybe need to suggest again to Chief Eric?
Thanks all.
Hey Eric, Chop.. and Charles.  YES, I am back on this, after I updated all the planes this AM.
Had a review with builder, and he has informed me that he was not wanting rafter tails after all, but exposed rafters.  Almost the same thing, but not to Chief.  Yes, Chief will give you exposed rafters, but not at a different size than the main rafter.  In this case, my roof rafters are 2 x 10's, but the exposed rafter is to be a 2" x 6" with a vertical block.  I created a little test model, because I didn't want to mess with main project model anymore.  On this test, the only way I can get this to work is two different planes of the same pitch, butted up to each other (can't join) and it is ugly on the shingle side (see below).  I also tried making a custom rafter tail, but can not scale it to be a 6" (5.5") piece of lumber.  Any other ideas, or thoughts...  ugh!  Any other training vids besides the ones via CA?
Just did a quickie test plan and it looks like you should be able to do a transparent ( Insulation Air Gap ) soffit material and a 5 1/2" sub fascia and then manually delete the sub fascia.  The custom rafter tail seems like it should work but this might be easier.
R U SERIOUS?  That's exactly what I've been trying to do.  I noticed that when I had soffit's in, it did the cut...  Never would have thought insulation air gap can be used as a invisible plane.  That's thinking outside the box.  Thanks for helping with this frustration of mine.  I will hit it tomorrow
Stay warm Chop!
The fire is on.B)   You might want to consider another look at the rafter tail theory as it may be a little cleaner overall.  I am not getting the artifact that Eric did and I am not really sure what that is.   The only issue I see is the soffit gives you a plum cut rafter heel and the rafter tail gives you a square cut rafter heel, if that matters.
8 minutes ago, solver said:
I turned off gable fascia and sub fascia, so it should not generate -- but it does.
Ok so you can not actually turn off the Gable Sub Fascia so you made is as small as possible and it created an artifact.  It seem that it can be deleted if necessary as I did with the Eave Sub Fascia in the previous soffit generated example.
The plumb and square rafter Heel cuts I was referring to in post 18 may not be the correct terminology but it is the area where the rafter is cut at the outside edge of the top wall plate that I circled in red.
9 hours ago, Chopsaw said:
Not done so quickly but as accurate as possible and it works but there seems to be an issue with the hip rafters.  As usual there is always something that breaks when you try to be more precise.
Rafter Tail Demo 2.zip
If precision is what you're after you might just need to select those hip rafters and replace and/or resize the rafter tail profile.
You don't need to delete the sub-fascia if you make the soffit transparent like an opening material.
Perry is absolutely correct.  Soffits set to use a Gap material type (like Insulation Air Gap) will disappear completely--even in vector view.  Gap material types work this way in various structure definitions.  To be honest though, I'm not sure I ever realized they work that way with soffits before.  If I did, I certainly forgot.  Thanks for pointing that out Perry.  Lots of good stuff in this thread.
Thanks MIchael,  I did not realize rafter tails could be applied to individual rafters.  That opens up more possibilities.
Thanks Perry,  I did not realize the sub fascia settings would still be active and cut the soffit when it is turned off.  That is a real bonus because it allows you to keep Auto roof turned on.   Do you use that setup often ?
  • mtldesigns changed the title to Underside of a roof plane
