Editing Auto Dimensions?
mountaineer
Randy, if you mean is there a setting for auto dims that will limit the number of dimension strings it produces, I do not think so.  You have to delete the ones you do not need.  Especially with interior dims, when there is a line for every wall in every room, plus openings etc.
On 11/28/2017 at 10:27 AM, BenPalmer said:
when ready to produce final docs, just turn off the auto refresh and delete the ones you don't want.  Or don't use auto and draw what you want manually.
How about, change auto dimensions color to red, select the ones you wish to keep, move them to manual dimensions layer and
then turn off auto dimensions
(Drawing before turning off auto dim.s)
