DesignPro-Diane Posted November 11, 2017 Share Posted November 11, 2017 My clients have selected bathroom mirrors with led lighting around the edge that eliminates the need for sconces. How can I show these? I've been working on it for several hours today, and nothing looks good. Tried just adding lights, but it doesn't give the glow around the edge in virtual-reality that I'd like to show them. Tried adding resized sconces behind the mirror, but that didn't work. Thought about using strip lighting that I use under wall cabinets for task light, but don't know how to change the orientation. Hope that someone has figured this out and can share how I can do it. Thank you! Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted November 11, 2017 Share Posted November 11, 2017 you can use a molding line with appropriate moulding shape and use a white color with high emissivity for looks. Actual light though would need to be a 3D light source. You could use spots with 180 cut off angled appropriately on each side. Link to comment Share on other sites More sharing options...
MarkMc Posted November 11, 2017 Share Posted November 11, 2017 13 hours ago, DesignPro-Diane said: Thought about using strip lighting that I use under wall cabinets for task light, but don't know how to change the orientation. Hope that someone has figured this out and can share how I can do it. Open symbol (not object)- 3D panel, rotate on the Y axis Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted November 11, 2017 Share Posted November 11, 2017 Here's one I did about 6 months ago. If this is what you are looking for let me know and I will pull it the light fixture from my library and post. Link to comment Share on other sites More sharing options...
mtldesigns Posted November 12, 2017 Share Posted November 12, 2017 I don't know if that what Diane is looking for Graham... but that's exactly hat I was I researching. Can you post or explain how you created it? Link to comment Share on other sites More sharing options...
