RCarter Posted September 4, 2017 Share Posted September 4, 2017 I'm working on a 10 unit condo and my computer is very slow but only when on this file. I keep getting a memory warning. I checked the properties and it's size is 11.5 MB this is twice what other projects are ( even when finished ). Because its a simple inline building I've used copy and paste a lot. Is there something I'm not aware of that's causing this I'm using CA-6Thank RCarter Colonial-10_unit_condo.plan Link to comment Share on other sites More sharing options...
dshall Posted September 4, 2017 Share Posted September 4, 2017 You need to close file before uploading. There is no file attached. Link to comment Share on other sites More sharing options...
RCarter Posted September 4, 2017 Author Share Posted September 4, 2017 Thanks for info Ten_Unit_Condo.plan Link to comment Share on other sites More sharing options...
dshall Posted September 4, 2017 Share Posted September 4, 2017 Some operations worked okay, putting in new doors and windows, but the 3d is painfully slow. I cannot explain why 3d is so slow. Link to comment Share on other sites More sharing options...
dshall Posted September 4, 2017 Share Posted September 4, 2017 There might be something to overusing copy/paste. I used copy /paste on a very simple mini storage building and that too was very slow. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2017 Share Posted September 4, 2017 I didn't have time to go through and test out the whole plan because it is so ridiculously slow on my system, but your problem is that you seem to have inadvertently created WAY WAY WAY too many copies of some things. If you marquis select your vanity base cabinet or one of your toilets you'll see that you have like 16-24 of each in many locations. That round sink alone has like 6,200 faces. Just based on the sinks I found (70 copies on the first floor and I think 16 copies on the second floor) you have an extra half a million faces in your plan. The same thing seems to hold true for every symbol I checked. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 4, 2017 Share Posted September 4, 2017 Everything seems to work ok on my system, only a little slow loading any 3d, but I can spin the model without any problems. I did notice after quickly looking that your wall definitions have no drywall, just a framing layer on all your walls, is that what you want? Link to comment Share on other sites More sharing options...
RCarter Posted September 4, 2017 Author Share Posted September 4, 2017 Where do I see the # of copies and is there a way to delete without individually deleting them Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 4, 2017 Share Posted September 4, 2017 21 minutes ago, RCarter said: Where do I see the # of copies and is there a way to delete without individually deleting them See the number of items selected here... ...if you see nothing there then you only have one item selected. To delete all but one, try one of these 2 methods... Marquis select the object thereby selecting ALL copies, hold down the Control key and click once to DE-select just one of the items, and then hit Delete. Or... Select one object or control select one each of several different objects, Hit Control+X (Cut), go through and group select/delete all the redundant copies, and then Hit Control+Alt+V (Paste Hold Position) to place the other(s) back into place. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 4, 2017 Share Posted September 4, 2017 Chief is rather straight forwardly created. So if your own procedures are weak or in error, Chief allows you to make such errors. Michael has discovered what you did to cause this plan to be overweight, so in the future make sure that when you make a copy that you are making a single copy of an object. Most such problems are End User Based predicated on wrong assumptions by that end user. It is part of the learning curve we all must mount. DJP Link to comment Share on other sites More sharing options...
dshall Posted September 4, 2017 Share Posted September 4, 2017 Nice catch Michael! 1 Link to comment Share on other sites More sharing options...
RCarter Posted September 4, 2017 Author Share Posted September 4, 2017 I basically selected each items and keep clicking select and delete.. But why did there items copy so many times. It was 5 units and the last units had about 25 copies of each item which decreased as I got closer to first unit. Anyway Thanks for all the help Link to comment Share on other sites More sharing options...
dshall Posted September 4, 2017 Share Posted September 4, 2017 1 hour ago, RCarter said: I basically selected each items and keep clicking select and delete.. But why did there items copy so many times. It was 5 units and the last units had about 25 copies of each item which decreased as I got closer to first unit. Anyway Thanks for all the help It would of been easier if you did a marquis select, (16 items preselected) hold down shift key and select (1 item deselected) hit delete and 15 items are deleted leaving one item. I do not know how you created so many items, but it sounds like you screwed up. 1 Link to comment Share on other sites More sharing options...
Smn842 Posted September 4, 2017 Share Posted September 4, 2017 1 hour ago, RCarter said: ....But why did there items copy so many times. It was 5 units and the last units had about 25 copies of each item which decreased as I got closer to first unit. What setting do you have for Preferences, Edit, Marquee Selection? Just wondering if its the default "Select Intersected Objects" and each time you've copied some object you accidentally copied other items as well so it increased as you progressed. If that's the case then one of the other marquee selection options may be better for your workflow as its harder to over select. Link to comment Share on other sites More sharing options...
