Sign in to follow this
ajrare
TEXT LAYERING
On Layouts would like to be able to layer Off some text, while keeping other text  On.    For example layer / turn off Structural text on the Electrical drawing while keeping electrical text on the Electric Layout Drawing.    Have seen examples on layouts sent to me.    Have spent some time on, and would be helpful if someone could shed light on how best to accomplish.  Thank you.
Place text on different layers. Turn on or off as needed.
At least use layersets (saved sets of layer settings), one for structural, one for electrical, etc. I use annosets to change layersets and more. Search on this forum for "layersets" and "annosets". It will be worth your time.
Perhaps look at some Articles in the KB about Layer Sets like these will be a start...
https://www.chiefarchitect.com/support/article/KB-00765/how-to-use-layer-sets.html
https://www.chiefarchitect.com/support/article/KB-00645/reassigning-several-objects-to-a-specific-layer.html
there are also some Videos if you have SSA
https://www.chiefarchitect.com/videos/#playlist-100
KBird has the right idea in that different annotation sets by default (when they are understood and used) automatically place text and other objects on appropriate layers while using a particular annotation set and you can customize annotation sets and create specialized text layers within those annotation sets to place text on whatever layer you desire. The "trick" if it can be so called is understanding, choosing, customizing annotation sets and their sets of layers to do your work for you while you work.
You use the Layer Sets in the Plan.  Then when you send a view to Layout it will use the current Layer Set.  As others have stated, setting up Annosets and Layer Sets is key.  It takes a little time, but once you have it done.......
    27499
    Bren0625
    Bren0625
