Joe_Carrick Posted June 7, 2017 Share Posted June 7, 2017 8 minutes ago, dshall said: I had never thought about this, but why would you want to do this? Is there an advantage? So you can share your symbol(s) with other users. All shared symbols on the Forum are calibz files. Link to comment Share on other sites More sharing options...
dshall Posted June 7, 2017 Share Posted June 7, 2017 22 minutes ago, Joe_Carrick said: So you can share your symbol(s) with other users. All shared symbols on the Forum are calibz files. Does putting the symbol in a plan and sharing the plan work? Link to comment Share on other sites More sharing options...
CADD16 Posted June 7, 2017 Share Posted June 7, 2017 I build my custom fixtures with Psolids as well, then just apply the a material to the front face. After I get done creating it with psolids I export it to a .3ds and then reimport it as a fixture, this way when I reimport it I can set it to be a certain kind of fixture. So the attached fireplace symbol is set to show up in my mechanical fixture schedule with the proper model number and description. Modern Fireplace.calibz Fireplace Fronts.calibz Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 7, 2017 Share Posted June 7, 2017 4 hours ago, dshall said: Does putting the symbol in a plan and sharing the plan work? Yes, but then the user has to save the symbol themselves to the Library. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 7, 2017 Share Posted June 7, 2017 1 hour ago, CADD16 said: After I get done creating it with psolids I export it to a .3ds and then reimport it as a fixture, this way when I reimport it I can set it to be a certain kind of fixture. We used to have to do it that way but now with "Convert to Symbol" you can set all of that in a single step. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 7, 2017 Share Posted June 7, 2017 2 hours ago, Joe_Carrick said: We used to have to do it that way but now with "Convert to Symbol" you can set all of that in a single step. Yup. All symbol types except "Cabinet". Still not sure why they've left that one out. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 7, 2017 Share Posted June 7, 2017 Just now, Alaskan_Son said: Yup. All symbol types except "Cabinet". Still not sure why they've left that one out. Because they requires some special geometry (faces with unique materials) to be drawers and doors and openings. Cabinet Symbols are simply not of much use. CA has improved the Cabinet Tool so much that creating Cabinet Symbols is IMNSHO of no value. Link to comment Share on other sites More sharing options...
CJSpud Posted June 8, 2017 Share Posted June 8, 2017 Thanks for sharing Chris. Can you tell me where the Modern Fireplace.calibiz gets placed in the library when I import it .... can't find it anywhere? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 8, 2017 Share Posted June 8, 2017 1 hour ago, CJSpud said: Thanks for sharing Chris. Can you tell me where the Modern Fireplace.calibiz gets placed in the library when I import it .... can't find it anywhere? Hi Curt ....it's actually Named Fireplace, Napolean NEFL60FH in your User Library. And Thanks Chris. Link to comment Share on other sites More sharing options...
CJSpud Posted June 8, 2017 Share Posted June 8, 2017 Thanks Mick ... I saw that but thought maybe I'd picked it up here from someone else awhile back. Now I know better. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 8, 2017 Share Posted June 8, 2017 15 hours ago, CJSpud said: Thanks Mick ... I saw that but thought maybe I'd picked it up here from someone else awhile back. Now I know better. The 2nd file Chris uploaded is 3 different Faces for the Fireplace ..ie different colours / flames etc so there are actually 4 files total the Fronts are in a Folder unsurprisingly called .....Fireplace Fronts ..... Link to comment Share on other sites More sharing options...
