zowie123 Posted May 23, 2017 Share Posted May 23, 2017 Hi all, Been a while.. Any time a stair extends past a wall, the rail jogs, what's the best way to rid this? I tried extending an invisible wall, but that doesn't work. Thank you, Barry Link to comment Share on other sites More sharing options...
javatom Posted May 23, 2017 Share Posted May 23, 2017 Pull the stair edge away from the wall just a bit and it will straighten out. 1 Link to comment Share on other sites More sharing options...
dshall Posted May 23, 2017 Share Posted May 23, 2017 11 hours ago, zowie123 said: Hi all, Been a while.. Any time a stair extends past a wall, the rail jogs, what's the best way to rid this? I tried extending an invisible wall, but that doesn't work. Thank you, Barry The invisible wall method does not work. Try putting the wall you extended on its own layer and turn that layer off. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 23, 2017 Share Posted May 23, 2017 This is a problem with automatic handrails that only CA can fix. I'm relatively sure that I've made that request previously but every suggestion sent to CA helps. Link to comment Share on other sites More sharing options...
zowie123 Posted May 23, 2017 Author Share Posted May 23, 2017 Hey, thanks guys! Chief is easy, it's the automation that takes 5000 hours of skill to end-run:) Cheers! 1 Link to comment Share on other sites More sharing options...
johnny Posted May 23, 2017 Share Posted May 23, 2017 53 minutes ago, zowie123 said: Hey, thanks guys! Chief is easy, it's the automation that takes 5000 hours of skill to end-run:) Cheers! I approve this message (TM). The negative effect caused by this could be somewhat mitigated if we could (a) explode all "object" models into shapes/groups and (b) had semi-decent generic modeling tools. 1 Link to comment Share on other sites More sharing options...
AvoyeDesign Posted May 25, 2017 Share Posted May 25, 2017 On 5/23/2017 at 2:42 PM, johnny said: I approve this message (TM). The negative effect caused by this could be somewhat mitigated if we could (a) explode all "object" models into shapes/groups and (b) had semi-decent generic modeling tools. Or if the automatically generated handrail had edit handles and nodes, like a molding polyine, that we could grab and adjust. And then the ballusters would follow suit. Link to comment Share on other sites More sharing options...
