dshall Posted March 26, 2017 Share Posted March 26, 2017 Where are rafters over porch at first floor See attached plan. The rafters over the lower porch do not frame unless I pull the roof away from wall. I am sure it is something I am doing wrong. Can you help me? Lin to plans https://www.dropbox.com/s/aab7hsal3kzsis0/no rafter at portch.plan?dl=0 no_rafter_at_portch.plan Link to comment Share on other sites More sharing options...
justmejerry Posted March 26, 2017 Share Posted March 26, 2017 Not sure what is going on with that. I copied and pasted the roof over to side and the rafters show. No matter what you do with that roof it will not show in that area...almost like something is over-riding the roof plane. I copied rafters from one I moved to side and the rafters show then. This is one for tech support I think. Unless Michael or Glenn figure it out. P.S The link under the pictures in your post download a corrupted file at 10mb but dropbox link above the pics is good. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 26, 2017 Share Posted March 26, 2017 The rafters show up for me in any 3d view, it's the plan framing view where they don't show up no matter what I do. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 26, 2017 Share Posted March 26, 2017 Why isn't there a "Porch Room"? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 26, 2017 Share Posted March 26, 2017 I added a porch room there and still no rafters there in 2d Link to comment Share on other sites More sharing options...
justmejerry Posted March 26, 2017 Share Posted March 26, 2017 I tried that earlier as well and turned on auto and all I got was the short wall rafters to show nothing else. However if it is changed to gable wall nothing. Link to comment Share on other sites More sharing options...
Northriver Posted March 26, 2017 Share Posted March 26, 2017 I opend 3D view I was able to make multiple copies of the end rafters at 24" OC across the roof. They show up on the roof plan. I closed the file and reopened and everything stuck. Hope this helps. Link to comment Share on other sites More sharing options...
glennw Posted March 27, 2017 Share Posted March 27, 2017 Scott, You have multiple roof trusses occupying the same space in the main roof. This, along with the Allow Low Roof Planes setting could be causing the problem. Once I delete all the trusses and auto build the roof, all behaves as it should. Link to comment Share on other sites More sharing options...
dshall Posted March 27, 2017 Author Share Posted March 27, 2017 Thanks all for looking. I tried Glenn's solution of deleting trusses auto rebuild roof and all was well. HOWEVER, if I put trusses at second floor roof, the rafters at the lower porch roof disappeared again. I think Perry has talked about how trusses do not allow lower rafters to build. I suppose I had hoped this was fixed by now but I guess not. A bit frustrating that something as basic as this is still not fixed. If I have time I will report it. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 27, 2017 Share Posted March 27, 2017 yep, its a problem and always has been Link to comment Share on other sites More sharing options...
