Denkam Posted February 26, 2017 Share Posted February 26, 2017 Hi Does anyone know if its possible to corner Garden windows? I have dragged together and removed corner post but can't join to the outer frame. I have also tried using atrium windows but won't join. (has the same problem) Thanks Rob Link to comment Share on other sites More sharing options...
RL-inc Posted February 26, 2017 Share Posted February 26, 2017 May have to use pline solids and create a symbol. Not wanting to jump too far ahead but before I spent a ton of time trying to create it in CA I would find out how much it is goung to cost to build. From engineering the wall to manufacturing that unit it looks like a pretty spend proposition to me. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2017 Share Posted February 26, 2017 10 hours ago, Denkam said: ....... Does anyone know if its possible to corner Garden windows? ..... The answer is no. Have you ever seen it done? Do you have a picture where it has been done? Are you living in la la land where anything is possible or are you living in the practical world. In the practical world the answer is no, if you are living in la la land, I bet I could do it if you post your plan. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2017 Share Posted February 26, 2017 The only thing I can think of would be to use walls to box out the windows then slam regular type windows together in the corner, but not the same. I guess you could make a symbol to do it. 1 Link to comment Share on other sites More sharing options...
javatom Posted February 26, 2017 Share Posted February 26, 2017 This is a good example of the DANGER of computer design software. It leads the public to believe its all about knowing the software. It is not. It's about know how buildings are built and what can be done in the real world. If you are serious about becoming a competent designer, put your keyboard away and pick up a hammer for a year or two. Some real world experience will show you why the program will not let you design that particular mistake. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2017 Share Posted February 26, 2017 2 minutes ago, javatom said: ....... It's about know how buildings are built and what can be done in the real world. ........ That is what I was trying to express ..... thanks Tom for clarifying. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2017 Share Posted February 26, 2017 I have actually seen a corner garden window a while back, must have been a custom built one. Link to comment Share on other sites More sharing options...
javatom Posted February 26, 2017 Share Posted February 26, 2017 Probably not one that would need to support an offset upper level as he shows in the picture. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2017 Share Posted February 26, 2017 10 minutes ago, javatom said: Probably not one that would need to support an offset upper level as he shows in the picture. I have always said that anything can be done if you want to pay for it, 2nd floor load doesn't bother me. Link to comment Share on other sites More sharing options...
Northriver Posted February 26, 2017 Share Posted February 26, 2017 I have not seen a garden window in new construction in over 20 years. It was popular in the 1970's thru mid 1990's. Same with Skywalls. Link to comment Share on other sites More sharing options...
Denkam Posted February 27, 2017 Author Share Posted February 27, 2017 Hi there Sorry I'm new to asking questions. The window is a window seat up off the floor and protruding approx.20inches from inside of 4inch wide framing. There is a corner post on the framing line holding lintels and floor loadings. When I said I took out the corner post out I was trying the see if the windows would join. The house was designed and built in the 80's its not a great design but its what's there as you can see from the photos. I am working on a cladding change for the customer and was just looking to see if there was an easy way to join a garden window to make my model true to what is built. I have been on the tools for 35 years and the last 15 doing design and build using C/A since Ver7 (now X9). I am no way experienced in using C/A to its full potential - Just trying to up skill where I can. Regards Rob 4 Link to comment Share on other sites More sharing options...
dshall Posted February 27, 2017 Share Posted February 27, 2017 Try this vid to see if it helps. 3 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 27, 2017 Share Posted February 27, 2017 9 hours ago, Denkam said: I have been on the tools for 35 years and the last 15 doing design and build using C/A since Ver7 (now X9). I am no way experienced in using C/A to its full potential - Just trying to up skill where I can. Ouch! We've got to be more careful guys about assuming too much about a poster - especially a new one! Rob's (Denkham) example is a good reminder - play nice, at least until you know more. 1 Link to comment Share on other sites More sharing options...
RL-inc Posted February 27, 2017 Share Posted February 27, 2017 Well said Ridge- Welcome Rob- good to have some more field construction experience to draw on here. The pictures of the existing structure you posted were very helpful in clarifying what you were after.s Great vid Scott- looks like Rob can get what he wants and just keep "corner post " checked in the framing DBX Link to comment Share on other sites More sharing options...
tommy1 Posted February 28, 2017 Share Posted February 28, 2017 Just a comment. I did a corner bay window for a job about a year ago sorta similar to this but wasn't full glass on sides and at the top, just glass in the outside corner. It did have a roof. This glass system was going to be installed by the window manufacturer who did these windows. When the lady took it to the city for permitting, the planning department rejected it and wanted to know how the glass was going to be attached everywhere because it had to meet a 110 mph. wind gust code. They wanted the specifics. I had the homeowner contact the manufacturer and had them attach a diagram on how this would meet code. I assume it was done. Never heard back. Link to comment Share on other sites More sharing options...
Denkam Posted March 1, 2017 Author Share Posted March 1, 2017 Thanks Scott I followed you vid and it worked perfect. Many thanks Regards Rob 1 Link to comment Share on other sites More sharing options...
Jacob123 Posted July 27, 2017 Share Posted July 27, 2017 Hearing this for the first time. Link to comment Share on other sites More sharing options...
