Kduke11
4GB Video Card
Just got a new Asus ROG laptop with GTX 1050Ti 4GB DDR5 and in Chief all it shows in the Render Video Card Status is 1GB. How do I change it to use the full 4GB??
The CA render engine uses the CPU; your CPU chipset may have a (dual) embedded 1GB video chip, which is what the CPU wants to use.  In any event, high-end GPU's do not decrease the ray trace render time in CA, for that you need a faster CPU clock speed and more threads.
This is a bug only in how Chief displays the available amount of video memory.  It will not impact how much video memory is actually utilized by Chief.
I have X8 and it shows the correct video memory 4095 MB. I think the poster is talking about the integrated chip being recognized over the discrete graphics chip. This needs to be set(assigned) in the Nvidia control  program.
Graham
So this is just a laptop thing then? My boss shows 2GB on his desktop and my home PC shows 4GB.
mine says 4095 when I actually have 6 gb
This is a real issue as my cursor is jittery on my plugable 3.0 station but only after I open a 3D view. If I don't open a 3D view the cursor is fine. Chief does not know why I only show 1GB when I have 4GB video card. They think the jitter has to do with the video card showing only 1GB. X8 works fine no issues even with 1GB showing. This is an X9 issue.
All I know is, that with every upgrade it takes a little more computer  power. Never goes the other way.
What Plugable 3.0 station are you referring to?  Is it something like this? http://plugable.com/products/ud-3900/  These kinds of docking stations that utilize USB graphics do not generally support high performance graphical applications very well (as is noted in the Gaming section in the link).  The core of our rendering technology has changed significantly in X9, which is likely why you see a difference in behavior from X8.
Yes like that. But even if I don't use it and only use the laptop I am still only showing 1GB in Chief with a 4GB card.
Ryan, when you say it has changed significantly what are you referring to.  I have found that in X9 my interior and exterior overview are not as clean lined as they were in X8.  They appear to be much more stigmatized.  I miss having my final view nd final view with shadows option, they made it so nice that I did not have to waste time in getting a decent Raytrace.
Question?
You stated in your original post that you have 4GB DDR.
That's not the same as a 4GB Video Card.  The video card could be 1,2 or 4 GB and as other's have stated; you need to make sure the Video Card is being used.  If it's NVidia set it in the NVidia control panel (PhysX)
Do you have this checked? It's taken the place of the Final View options.
Setting Ambient Occlusion down from 100% seems to help the dirt in the corner look the the default setting gives.
Actually for me that" Edge smoothing when idol", slows me down. not sure why but I have a very fast system. So I leave it off.
The edge smoothing helps the look Perry but doesn't make it any slower since I think with all the crap I got in this files it is already slow to begin with.  Thanks for the tip.
I think what I'm saying, is that, I really don't need to wait for the edge smoothing to kick in after the fact ,and my system doesn't have to put that regeneration at the end. I also don't have any resolution problems.
    28876
    HarmonCA
    HarmonCA
