Rosco2017 Posted January 29, 2017 Share Posted January 29, 2017 I'm not that computer savy at all. I can't for the life of me figure out how to work sketch up, nor do I have the time to learn it with the amount of workload I've been carrying. I need this column cut in half vertically. Is there an easy way to do this? I intend to use this on the exterior of a home. I'll attach a pic. column.plan Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2017 Share Posted January 29, 2017 Here ya go, done using SU. column.plan 1 Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 29, 2017 Author Share Posted January 29, 2017 27 minutes ago, solver said: Like this? Yes. Can this be achieved in Chief? Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2017 Share Posted January 29, 2017 Take us through that process of symbol editing, Eric. I need to learn it. Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 29, 2017 Author Share Posted January 29, 2017 26 minutes ago, GeneDavis said: Take us through that process of symbol editing, Eric. I need to learn it. That is wonderful! Thank you Gene! Link to comment Share on other sites More sharing options...
MarkMc Posted January 30, 2017 Share Posted January 30, 2017 To cut the symbol in half -add a stretch zone that goes from then back to the center of the object, resize the depth to half what it was. Almost forgot- once done open the symbol again, block tab, generate block so it shows correctly in plan. 5 Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 30, 2017 Author Share Posted January 30, 2017 Thank you guys so much for all of your help. I really appreciate it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 30, 2017 Share Posted January 30, 2017 Mark's method is what I've been using for about 4-5 years. Link to comment Share on other sites More sharing options...
jgauntz Posted May 19, 2020 Share Posted May 19, 2020 I used the below instructions: "To cut the symbol in half -add a stretch zone that goes from then back to the center of the object, resize the depth to half what it was. Almost forgot- once done open the symbol again, block tab, generate block so it shows correctly in plan." But cannot get it to work. I take a newel post and add it to my plan. I then open the newel post as a symbol and set the y plane to cut the newel in half. I then click ok and then I open the same symbol in my plan and I generate block. Then I add the block to my plan - but I cannot see it and it does not appear to be cut in half. Link to comment Share on other sites More sharing options...
jgauntz Posted May 19, 2020 Share Posted May 19, 2020 OK - I somehow got it to do what I needed. Now just need to see if I can repeat it :) Link to comment Share on other sites More sharing options...
Kbird1 Posted May 20, 2020 Share Posted May 20, 2020 On 1/29/2017 at 4:02 PM, MarkMc said: To cut the symbol in half -add a stretch zone that goes from then back to the center of the object, resize the depth to half what it was. Almost forgot- once done open the symbol again, block tab, generate block so it shows correctly in plan. thanks Mark.... for anyone else trying this with Ross's Plan from the OP , note he has already resized the Column in that plan from it's original size ( 26 x 26 x 107 9/16 ) via Open Object to 16" x 16" x 72" so the "halving" doesn't work as expected in that Plan. Either reset the size to Original or start with your own symbol at full size 1st. Then in the Open Object DBX set the Depth to 1/2 M. Link to comment Share on other sites More sharing options...
