Alaskan_Son Posted January 19, 2017 Share Posted January 19, 2017 I noticed my Chief Architect Premier X9 Data folder is a little different than in previous versions. It seems to be missing these 2 files... ...and these files seem to be new... Not sure it really matters as I don't seem to be having any problems, but I would also kinda like to understand what's going on. Any of yuze guys happen to have any insight? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 19, 2017 Share Posted January 19, 2017 sheetSizes is a leftover from X6 - it was eliminated in X7 mmaster is the Materials List Master file - you can recreate it in CA - or copy from a previous version Data Folder. The Migrate Folders are just copies of the X8 Folders. I think they were just created during the installation of X9 and probably are not needed. The install should (IMO) have deleted them on completion - but it will require someone at CA to verify that. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 19, 2017 Author Share Posted January 19, 2017 3 minutes ago, Joe_Carrick said: sheetSizes is a leftover from X6 - it was eliminated in X7 mmaster is the Materials List Master file - you can recreate it in CA - or copy from a previous version Data Folder. The Migrate Folders are just copies of the X8 Folders. I think they were just created during the installation of X9 and probably are not needed. The install should (IMO) have deleted them on completion - but it will require someone at CA to verify that. Re: sheetSizes...Thank you. I wonder why it was present in both X7 and X8 folders? It must have just been carried over during the migration process? Oh well...as long as its not necessary. Re: mmaster...That's kinda what I figured. Just wasn't sure if perhaps something had gone wrong during the initial migration/install. I went back and double checked and it looks like Chief is still using one of the Master Lists located in my X8 folder. I've never really utilized Master Lists except for learning and playing around with them so its probably a non-issue but I went ahead and created a new one in my X9 folder for if and when I do make use of it. Thanks. Re: Migrate Folders...Thank you for verifying. That's kinda what I figured on those as well but I wasn't sure. I wonder if I'm safe to delete them. I take it you don't have them? I probably ought to contact TS to make sure its okay if I clean that folder up. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2017 Share Posted January 19, 2017 I noticed the extra Folders, they are empty (here) but I left them alone for now "just incase".... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 19, 2017 Author Share Posted January 19, 2017 18 minutes ago, Kbird1 said: I noticed the extra Folders, they are empty (here) but I left them alone for now "just incase".... Mine aren't all empty. The Templates and Toolbars folders are both full. I went ahead and sent a ticket into tech support. My migration log shows one error... "....Premier X9 Data\Patterns Migrate From Directory does not exist. Copying Textures Directory Migrate From Directory: C:\Users\User\Documents\Chief Architect Premier X8 Data\Textures Migrate To Directrory: C:\Users\User\Documents\Chief Architect Premier X9 Data\Textures***ERROR: Migrating TexturesDirectory Migrating Preferences Copying Chief Architect Premier X9.ini File Migrate From File: C:\Users\User\AppData\Roaming\Chief Architect Inc\Chief Architect Premier X8.ini Migrate To File: C:\Users\User\AppData\Roaming\Chief Architect Inc\Chief Architect Premier X9.ini..." I'm assuming the folders weren't deleted because there was that one error during migration. I noticed in another thread you mentioned you have missing textures. I suspect your migration log also has a similar error message and your migration folders were probably not deleted for the same reason as mine. That's just a guess though. I suppose I'll wait to hear what the fine folks at TS have to say. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2017 Share Posted January 19, 2017 2 hours ago, Alaskan_Son said: Mine aren't all empty. The Templates and Toolbars folders are both full. I went ahead and sent a ticket into tech support. My migration log shows one error... "....Premier X9 Data\Patterns Migrate From Directory does not exist. Copying Textures Directory Migrate From Directory: C:\Users\User\Documents\Chief Architect Premier X8 Data\Textures Migrate To Directrory: C:\Users\User\Documents\Chief Architect Premier X9 Data\Textures***ERROR: Migrating TexturesDirectory Migrating Preferences Copying Chief Architect Premier X9.ini File Migrate From File: C:\Users\User\AppData\Roaming\Chief Architect Inc\Chief Architect Premier X8.ini Migrate To File: C:\Users\User\AppData\Roaming\Chief Architect Inc\Chief Architect Premier X9.ini..." I'm assuming the folders weren't deleted because there was that one error during migration. I noticed in another thread you mentioned you have missing textures. I suspect your migration log also has a similar error message and your migration folders were probably not deleted for the same reason as mine. That's just a guess though. I suppose I'll wait to hear what the fine folks at TS have to say. You are Correct Michael . I only checked 3 or 4 of the *_MigrateBackup Folders which where empty , my textures and Toolbars_Migrate folders have Items too, My Log does not show any errors though. Actually I thought Toolbars didn't migrate to be honest and you had to set them up again.... but I should of migrated X7-X8 properly then installed X9 since it only migrates the most recent version. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 19, 2017 Author Share Posted January 19, 2017 4 minutes ago, Kbird1 said: Actually I thought Toolbars didn't migrate to be honest and you had to set them up again.... Ya, I think that feature is new with X9. I had some pretty complex custom toolbars and toolbar configurations and it was really nice to have those automatically migrated. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2017 Share Posted January 19, 2017 19 hours ago, Alaskan_Son said: Ya, I think that feature is new with X9. I had some pretty complex custom toolbars and toolbar configurations and it was really nice to have those automatically migrated. Thanks for the Tip , not sure I should of but I renamed the X9 Toolbar Folder and Copied the Toolbar Folder from X7 into the X9 Folder and restarted X9 and My Custom Toolbars and their layout are back phew.... Only thing is now I am unsure what my Toolbars should have with the new features etc. in X9 and if they can display the new features?. P.S . Just found your YouTube Channel too Michael, (MichaelB for those who don't know yet) so thanks for putting those up as well. Perhaps put a link in your sig. ? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 20, 2017 Share Posted January 20, 2017 I deleted my "Migrate folders" without any problems Link to comment Share on other sites More sharing options...
Rich_Winsor Posted January 20, 2017 Share Posted January 20, 2017 6 hours ago, Kbird1 said: P.S . Just found your YouTube Channel too Michael, (MichealB for those who don't know yet) so thanks for putting those up as well. Perhaps put a link in your sig. ? Hey Mick. Good to see you back. For a while there I thought you had fallen off the face of the earth. I even posted in the Chat Room asking about your whereabouts, but nobody cared. BTW, you might want to edit your listing for Michael's YouTube Channel. Link to comment Share on other sites More sharing options...
jcaffee Posted January 20, 2017 Share Posted January 20, 2017 Clean install on a clean machine... Link to comment Share on other sites More sharing options...
Kbird1 Posted January 20, 2017 Share Posted January 20, 2017 10 hours ago, Rich_Winsor said: Hey Mick. Good to see you back. For a while there I thought you had fallen off the face of the earth. I even posted in the Chat Room asking about your whereabouts, but nobody cared. BTW, you might want to edit your listing for Michael's YouTube Channel. Hi Rich , good to see a familiar face ..... it wasn't quite the End of the World , just felt like it without Internet, (so no Chief) Cable, etc but thankfully that Project is finished, but now I feel like I need to learn Chief again Here's hoping the Workload is better in 2017 and keeps me in Town ..... Ooops Apologies to MichaelB too .... fixed Link to comment Share on other sites More sharing options...
