Demr7777 Posted December 11, 2016 Share Posted December 11, 2016 New to Chief and just got done designing a house for a client. Well I'm almost done...Anyway now they want the plan reversed. O.K. figured it would be as easy as it is in AutoCad. NOPE! Auto cad just select all and mirror...done. Chief....I have no clue. Well I take that back. I have tried the (mirror the plan which is a lot of steps to just mirror the plan) but it mirrored with my windows in different places. missing colors,and roof framing sticking out all over the place to name a few issues. How frustrating! Now I'm reading a lot of how to's on line and its like reading a book full of steps. Is there a EASY way to do this? I also keep reading people referring to keeping the drawing on or near the 0,0 axis. I don't even know how to do that. I really need to flip this plan. Might just have to convert to autocad and mirror there but I don't think I will ever get it back to Chief again. Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted December 11, 2016 Share Posted December 11, 2016 There is a reverse plan tool. I'm on a computer that doesn't have CA so I don't know which of the rows at the top it is located under. Hover over the ones in the middle and the reverse plan command is the last command at the bottom of the list. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 11, 2016 Share Posted December 11, 2016 A couple ways... 1. Edit>Edit Area>Edit Area (All Floors). Marquis select everything and then either use Transform Replicate and Reflect or use Reflect About Object. 2. Tools>Reverse Plan as Jay mentioned. The latter will not reverse any of your terrain stuff. Only the house. NOTE: You can also optionally use Edit Area in one of the other modes if you want to be more selective with what you are flipping. Link to comment Share on other sites More sharing options...
Demr7777 Posted December 11, 2016 Author Share Posted December 11, 2016 Okay sorry for the delay had to step out for a while. I just tried the Tools>reverse plan...It works but everything disappears that I worked on like all my stone veneer. siding color and the framing in the roof keeps exposing itself as well as the rafter tails. I don't get it. It's like all the changes I made go back to default as well. I guess I will try the other method you spoke of Alaskan_Son .. But I think I tried that earlier today and it had the same results. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 11, 2016 Share Posted December 11, 2016 You will have to re-frame everything though. Just turn on auto framing on walls roofs and ceilings/ floors, but if you have some custom manual framing, don't turn on auto framing or you will lose that, you may have to re-do it. using edit area might save it. Try it you can always go back. Link to comment Share on other sites More sharing options...
lbuttery Posted December 11, 2016 Share Posted December 11, 2016 in the past I had no issues (that I remember) in reversing a plan perhaps those plans were "simple" so to hear that there are these types of issues is disturbing especially about having to re-frame why would stone veneer and siding colors disappear - that is just wrong !!! since we are now on ver 18 of Chief this should be a one-click operation Lew Link to comment Share on other sites More sharing options...
joey_martin Posted December 12, 2016 Share Posted December 12, 2016 You have something wrong somewhere. I reverse plans for builders a couple times a month as they sell more lots...one click, cleanup some of the text and done. The entire process should take less than 5 mins. Link to comment Share on other sites More sharing options...
BenPalmer Posted December 12, 2016 Share Posted December 12, 2016 Reversing is typically pretty smooth. But usually some cleanup in the elevations saved cameras: i.e. left to right, or east to west, and some labeling gets off. Also some 3d work such as solids can occasionally be a problem. Pretty good, but not perfect. Link to comment Share on other sites More sharing options...
