jimmyp Posted October 16, 2016 Share Posted October 16, 2016 Any ideas why I have these duplicate entries in my door schedule? I tried copy and pasting and chief changes the label... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 16, 2016 Share Posted October 16, 2016 Header sizes are different. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 17, 2016 Share Posted October 17, 2016 A lot of times I see multiple entries in the Schedules ,so I then have to open each schedule and uncheck, then check "group similar objects" to fix, not updating as it should most of the time. Link to comment Share on other sites More sharing options...
dshall Posted October 17, 2016 Share Posted October 17, 2016 Header sizes are different. That is interesting. Is that a bug? I never use "group similar objects", makes it easier to identify duplicates...... besides...... I think each door should have a unique label ...... it seems like a 2668 door whether hinged left or right somehow gets grouped as a duplicate door even though the swing is different. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 17, 2016 Share Posted October 17, 2016 If I don't use group similar objects, the schedule just gets too big to fit all the schedules on a page b/c I really want to use the 2d drawings of windows and doors. I know I can resize that column, then it gets too small to see what it is. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted October 17, 2016 Share Posted October 17, 2016 If there is just ONE thing that is slightly different in the displayed columns, then a new line will be created for those objects which would be grouped otherwise. (In this case, headers are slightly different.) For example, if you remove the "header" column, then the doors will group as you wish, but you will have to click the renumbering icon to renumber the labels, too. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 17, 2016 Share Posted October 17, 2016 That is interesting. Is that a bug? I never use "group similar objects", makes it easier to identify duplicates...... besides...... I think each door should have a unique label ...... it seems like a 2668 door whether hinged left or right somehow gets grouped as a duplicate door even though the swing is different. You have to either check "Include Type" in the label tab of the schedule dbx or add the "Hinge Side" column to keep differing swings from grouping together. Link to comment Share on other sites More sharing options...
dshall Posted October 17, 2016 Share Posted October 17, 2016 You have to either check "Include Type" in the label tab of the schedule dbx or add the "Hinge Side" column to keep differing swings from grouping together. got it..... Link to comment Share on other sites More sharing options...
jimmyp Posted October 20, 2016 Author Share Posted October 20, 2016 You have to either check "Include Type" in the label tab of the schedule dbx or add the "Hinge Side" column to keep differing swings from grouping together. or turn the description column on Thanks Everyone! Link to comment Share on other sites More sharing options...
JLDrafting Posted October 20, 2016 Share Posted October 20, 2016 This may not be the same problem, but I have tried to get rid of the extra door call-out to no avail. This is a single story project that has been modified a lot of times, however. All doors have two call-out symbols. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 20, 2016 Share Posted October 20, 2016 This may not be the same problem, but I have tried to get rid of the extra door call-out to no avail. This is a single story project that has been modified a lot of times, however. All doors have two call-out symbols. Jim, You have 2 Door Schedules - maybe one in the Floor Plan View and another in a CAD Detail. Delete the one in the Plan View and there will only be one call-out per door. Link to comment Share on other sites More sharing options...
JLDrafting Posted October 20, 2016 Share Posted October 20, 2016 Good advice Joe, but I cannot find another schedule anywhere in the plan. Deleting the schedule does get rid of the double call-out, but then I get different (additional) door designations that do not match the door schedule. This plan layout has been revised many times and may be corrupt. I don't use the schedules normally. I'm working with a new Engineer that takes my drawings (2-D drafting) and inserts them into his formatted sheets that include door and window schedules. The door and window installers have done their own take-offs in the past. I thought I'd experiment with the CA schedules and came across this anomaly. The project has already been permitted, but I went back to explore a bit. I have not gone back to other projects to try. Thanks Joe. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 20, 2016 Share Posted October 20, 2016 Jim, I don't know where your 2nd Door Schedule is located - but there must be 2 Door Schedules. If you can post the Plan & Layout I'll see if I can find it for you. Link to comment Share on other sites More sharing options...
BruceKC Posted October 24, 2022 Share Posted October 24, 2022 OK, so on the door schedules, even though I had "group similar" checked, I also had "Room names" in the schedule, and without thinking, it can't group similar doors if they're in different rooms... hope that helps someone. Link to comment Share on other sites More sharing options...
Woodward4 Posted May 9, 2024 Share Posted May 9, 2024 On 10/24/2022 at 2:24 PM, BruceKC said: OK, so on the door schedules, even though I had "group similar" checked, I also had "Room names" in the schedule, and without thinking, it can't group similar doors if they're in different rooms... hope that helps someone. Is there a way to "ignore" columns like Room Name that we know are going to be different but want to group similar items anyway and still display those columns that have the differences? For example, I want all 2668 R In doors to be grouped together, but I want to display the different room names for those doors in the column and not have a separate row for each door. Link to comment Share on other sites More sharing options...
