How to get rid of the room lines showing through in 3D views?
GeneDavis
The walls really should align and must be the exact same wall, Check the alignment and thickness sometimes those lines will be eliminated by making the lower wall balloon through the floor/ ceiling above. Also if you are using a different texture/ thickness between upper and lower walls, you will also get that line. Keep you elevations live, for me that works better, especially with changes. I never go to cad details for elevations, ever.
