chief58 Posted September 17, 2016 Share Posted September 17, 2016 I have been having trouble with my computer lately shutting down at different times, sometimes it would run all day and sometimes it would just shutoff, my computer guy thought it might be the power supply so he ordered me a new one and I installed it today and it still shuts down, turned it on and it would shut down let it sit for a while and turn it on and it would run for about a half hour then shut down, let it sit and start and would run for about an hour, the power supply is a Corsair CX750M 750W MODULAR TYPE and still no difference, has anyone else had this problem them with there’s and knows what could be causing this. Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 17, 2016 Share Posted September 17, 2016 No thank God, It could be weak RAM or a failing Mother Board but I am no Computer Geek, Perhaps a failing or slow cooling fan which causes components to overheat after a while. DJP Link to comment Share on other sites More sharing options...
chief58 Posted September 17, 2016 Author Share Posted September 17, 2016 Thks DJP guess that is the next things to look for at this point it is hope and poke unless someone else has had an experience like this Link to comment Share on other sites More sharing options...
Chopsaw Posted September 18, 2016 Share Posted September 18, 2016 Ray, I was having some issues with my Dell recently and found out that you can run a complete hardware diagnostic test by pressing F12 during boot up and choosing diagnostics. Link to comment Share on other sites More sharing options...
chief58 Posted September 18, 2016 Author Share Posted September 18, 2016 Ray, I was having some issues with my Dell recently and found out that you can run a complete hardware diagnostic test by pressing F12 during boot up and choosing diagnostics. Thanks Chopsaw will give that a try in the morning Link to comment Share on other sites More sharing options...
Rosco2017 Posted September 18, 2016 Share Posted September 18, 2016 I had this issue and it turned out my hard drive was going bad. But I'm no expert as to what your issue is. I would be going along minding my own business and POW! it would just shut right off like it was unplugged. Sent it to Asus and they sent it back with a new HD and said it had failed. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 18, 2016 Share Posted September 18, 2016 I think it overheating, did a fan go out? Try taking the cover off and run it for a while. if it's a laptop clean and vacuum the inside and vent holes. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 18, 2016 Share Posted September 18, 2016 I agree with Perry in that I clean and vacuum my case and components at least once a month, not doing this can make your cooling system not function properly which leads to over heating which leads to hardware failures. You do not need to be a Geek to do that sort of maintenance, just read some articles on line FIRST to learn the basic procedures. DJP Link to comment Share on other sites More sharing options...
chief58 Posted September 18, 2016 Author Share Posted September 18, 2016 Perry it's a desktop and when I changed the power supply I cleaned the whole unit and all fans were working there are a couple fans in the unit and all holes are open and clean Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 18, 2016 Share Posted September 18, 2016 Just try running it with the cover off and see if it shuts off-then go from there Link to comment Share on other sites More sharing options...
BrownTiger Posted September 18, 2016 Share Posted September 18, 2016 Could be CPU overheating. You need to look at windows event log, for Microsoft-Windows-Kernel-Power. Get something like HWMonitor to see if CPU runs hot. Error could be driver related. In that case also check with the event log. Link to comment Share on other sites More sharing options...
chief58 Posted September 18, 2016 Author Share Posted September 18, 2016 The crazy thing is after leaving it turned off all night I started it about 10:30 this morning for a meeting with clients at 11:00 am and it has been running since with no shutdowns ever since and I just checked it know, will try and see when it shuts down again, what a crazy thing when you need to get the work done, using this laptop is ok but I like the bigger screen and dual monitors Link to comment Share on other sites More sharing options...
chief58 Posted September 18, 2016 Author Share Posted September 18, 2016 Could be CPU overheating. You need to look at windows event log, for Microsoft-Windows-Kernel-Power. Get something like HWMonitor to see if CPU runs hot. Error could be driver related. In that case also check with the event log. Thanks for the info I will give it a try Link to comment Share on other sites More sharing options...
