morkas
Any way to redefine ceiling outlets?
I have placed several outlets in the ceiling of my covered porch for Christmas lighting and the like.  I would like them to be defined as weatherproof; however, the only option for ceiling outlets as far as I can see are regular duplex outlets.  I do see where I can change the label, but that does nothing to change the actual type.  This keeps coming up on my plan check, which I am admittedly a bit obsessed with.  Any suggestions?
Peace,
Teresa
You need to modify the 2D Block to include WP and save the outlet to your user Library so it's available for future projects.
If You like you can use the existing "Duplex (weatherproof)"  and open the symbol DBX and go to Options tab and select Ceiling Mounted Placement and then rotate using the tools in the 3D tab and also control the elevation in the Std. DBX.  As Joe said then change the 2D block and add to library for next time.
Michael did a good video on 2D Cad Block a while back: https://chieftalk.chiefarchitect.com/index.php?/topic/8942-fancy-cad-blocks-for-symbols-that-remain-consitent-between-2d-and-3d/#entry79240
FWIW, ceiling mounted outlets should not need to be weatherproof.  Assuming that they are under the roof there shouldn't be any way for them to get wet.  If you mount a light fixture or fan on the ceiling of a porch for example, they don't have to be waterproof fixtures.
Maybe it's just a matter of a notation on the plan that the outlets are "ceiling mounted".  Or, you could indicate a light fixture and then have the fixture changed to an outlet later.  GFCI protection could also be used.
Thanks for the info.  I agree that a weatherproof outlet should not be required, but honestly I don't know what the code is and sometimes it can be a bit quirky.  This does beg another question... is there a way to ignore an error in the plan check just as you can in spell check in MS Word?
They may not be impacted by rain but there is an issue with insects here in Florida. So the spring loaded covers do a good job of keeping those little critters out.
NEC 408.8
( A ) Damp Locations. A receptacle installed outdoors in a location protected from the weather or in other damp locations shall have an enclosure for the receptacle that is weatherproof when the receptacle is covered (attachment plug cap not inserted and receptacle covers closed). (Gasketed Outlet)
An installation suitable for wet locations shall also be considered suitable for damp locations.
A receptacle shall be considered to be in a location protected from the weather where located under roofed open porches, canopies, marquees, and the like, and will not be subjected to a beating rain or water runoff. All 15- and 20-ampere, 125- and 250-volt nonlocking receptacles shall be a listed weather-resistant type.
( B ) Wet Locations. (1) 15- and 20-Ampere Receptacles in a Wet Location. 15- and 20-ampere, 125- and 250-volt receptacles installed in a wet location shall have an enclosure that is weatherproof whether or not the attachment plug cap is inserted. All 15- and 20-ampere, 125- and 250-volt nonlocking receptacles shall be listed weather-resistant type
It is up to your building inspector to interpret it. I would install a gasketed outlet.
Please forgive my ignorance.  It's probably right in front of me, but I do not see an "options" tab in the DBX for the outlet.  Listed are General, Layer, Materials, and Label.  There are Options under the General tab (Reverse Symbol, Include in Schedule), but I see nowhere where I can change the outlet from a wall mount to a ceiling mount to create what you have created in your thumbnail. I'm sorry, but I'm pretty new at doing anything more than designing a pretty looking (but not mechanically functional) house on the default layer.  We all have to start somewhere.
Teresa,
Are you talking about Chief's "Plan Check" or the one done by the Building Dept?
Teresa,   Sorry but I did not mean to leave you on you own but I was able to enjoy a day off.  Looks like Jerry was able to give you what you needed.  When you are ready to there is a whole new world to explore with symbols by opening them with this tool  post-4797-0-81164400-1468803847.jpg  that I referred to this morning.  This is also where you need to be to edit the associated 2D cad block.
Jerry, Nice work on your symbol.  Did you recreate or just edit? Your offsets seemed to work out better than mine.   Always learning.
Jerry to the rescue again.  :)  Thanks guys!  I am eager to explore the "whole new world" that you speak of Chopsaw, and fully intend on some training next year.  Unfortunately, I need to finish this project within a few short weeks to be ready for an engineer's approval and it is becoming clearer by the day how much I do not know.  I hope to look back on this time someday and smile at what little knowledge I once had, but for now it's just frustrating.  Luckily, everyone I have run into on this forum has been very giving of themselves and their knowledge.  Thanks again!
You're welcome Teresa. Chopsaw, I copied a wall mount and edited. Made it ceiling mount and  changed the x rotation and removed the numbers for z and saved. Then put it in plan and fixed the 11 1/2" offset it gives from ceiling and saved to library again. Somewhere along the way I edited the cad block for the text to remove that awful Arial font lol.
Thanks Jerry, I was in a hurry and missed the step of saving to library and then placing back into plan. The library seems to also be a hospital as it seems to rewrite the file and clean it up. My symbol still wanted to snap to the wall after editing (see attached) but was restored in the library (hospital).
If you have a preferred custom font you can set up your "Default Label Style" so you always get that. Default Settings> Text, Callouts and Markers> Text Styles> Default Label Style> Edit (Not Arial)
I have all my fonts set to ARchitext font. The "WP" is part of original cad block so had to change it. The label is completely different.
    27461
    WaunakeeDesigner
    WaunakeeDesigner
  • Similar Content
    • By mtldesigns
      I know there must be a setting based on room type, but having no luck finding it, and its probably right in front of my face.  My bathrooms, and other "wet" rooms have no issue of a GFI coming in automatically.  My last three plans have had this issue, so I either messed with something in the defaults or who knows?  Right now, my work around is copy paste from bathroom, but that's not how it should be.
      Thanks for any help in advance.
    • By brucecurtis
      How do I place a regular duplex outlet on a kitchen island without the software changing it to a weatherproof outlet?
    • By CJSpud
      I was experimenting with using the Build > Electrical > Auto Place Outlets functionality in X7 and ran into some interesting behavior discoveries.
      1.  When I auto placed outlets in the kitchen room, Chief ignored the room divider that I have separating the kitchen room from the living room and placed outlets in both rooms.
      2.  Chief "also" placed a default light over the kitchen sink even though the light obviously is not an outlet.
      3.  For the cooktop and hood, Chief placed GFCI outlets for both appliances on the wall behind the base cabinet that the cooktop is installed in.
      4.  I have a 48" base cabinet to the right of the cooktop and Chief would not place a GFCI outlet above the cabinet anywhere.
      5.  For the island, I used a couple of 36" bases on one end and put a 32" kitchen sink in one of those to see if Chief would put a light over it (like it did for the sink base against the wall ... it did not ... therefore, I am assuming Chief only places a light over a kitchen sink against a wall.
      6.  In the attached plan, in the bath, I placed a double vanity that I had created in X4 or X5 and saved to the library as an architectural block.  When I did the Auto Place Outlets for the bath, Chief did not add any electrical outlets or lighting to the bath.  Next, I selected by double vanity and change the layer to Cabinets, Base and then ran the Auto Place Outlets tool again and still no electrical got placed into the bath.  Next, I exploded my double vanity into two separate base cabinets with sinks and ran the Auto Place Outlets tool one more time and Chief this time placed default default "wall" light fixtures over each sink but didn't place any GFCI(s) on the wall.
      7.  Curiosity is getting the best of me now.  I place another base cabinet (24" wide) with a round sink from the Library on the wall in front of the toilet and then run Auto Place Outlets again to see what happens.  Chief this time puts a light and a GFCI on the wall behind this cabinet and again puts lights above each sink of my saved and exploded vanities with sinks (from my user library) but still no outlet behind either of these vanity cabinets.
      8.  Next, still in the curiosity mode, I place a base cabinet (no sink) between my exploded double vanity cabinets on the left wall and the tub/shower fixture ... then ran Auto Place Outlets again.  Chief now places a GFCI outlet to the right side of the newly placed base cabinet as well as the same results as reported in #7 above.
      9.  I tried several other sink/cabinet combinations to see what Chief would do with them when I ran Auto Place Outlets when each as added to the bath room:
      a.  A base cabinet with the "Flair Oval Vessel Sink" placed on the countertop (unblocked) does get a GFCI on the wall but no light above.  If you block that sink to the base, I didn't get an outlet or a light.  I am not sure why that sink doesn't become associated with the base cabinet when placed on it and the placement doesn't want to attach to the center of the base cabinet either, which I think it should.
      b.  A base cabinet with a kitchen sink placed in the bath room will get a ceiling mounted light but no GFCI.
      c.  A base cabinet with a "Bowl" sink (small sink - possibly for kitchen islands ??) place in the bath room gets neither a wall or ceiling light nor an outlet.
      d.  A base cabinet with a "Bowl (undermount)" sink placed in the bath room yields a ceiling light but no wall outlet (go figure!!!).
      e.  A "Chunky Pedestal" sink from the Library placed against the wall yields both a default wall light and a GFCI on the wall.  Out of curiosity, I bumped the sink 1" away from the wall and still got the light and outlet when running Auto Place Outlets.  If I continue bumping that sink out away from the wall, I lose the ability to get a light and outlet when it is 4" away from the wall.
      f.   When I placed an "ELU1511" (oval sink - possibly another kitchen prep sink) in a cabinet, I get a ceiling light overhead but no outlet.
      Conclusions:
      I think the one observation that baffled me the most was why my library saved double vanity didn't generate any wall GFCI outlets, even when exploded to individual cabinets?  Another was why wasn't I able to get Chief to place a GFCI to the right of the cooktop above the 48" base cabinet?
      I think there's some inconsistent or improper behavior going on with some of Chief's library symbols that could use some cleaning up.  I only sampled a few so I don't have a clue how the rest will work in a plan.  Hopefully, the Chief content developers will take a look at all their library symbols that have functionality with the Auto Place Outlets tool and make sure they all function in a logical manner.
      AutoPlaceOutlets.zip
