johnny Posted July 8, 2016 Share Posted July 8, 2016 I'm curious how people are handling this situation - For basement foundation/framing walls is it better to create a custom wall type with all the layers (including the framed interior wall), or have 2 separate walls? Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 8, 2016 Share Posted July 8, 2016 I have done it both ways, I generally prefer the two wall way, using an interior wall with sheetrock on only one side. DJP Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 8, 2016 Share Posted July 8, 2016 I prefer modelling things as close as possible to the way they will actually be constructed so I'd say 2 walls in most circumstances. Not sure I can give you a lot of reasons per se...just feels better to me and I think it also offers a little better control. Link to comment Share on other sites More sharing options...
justmejerry Posted July 8, 2016 Share Posted July 8, 2016 Usually always two walls. If you want any type of sub-floor structure such as dri-core etc. it will stop at wall not under it. Layers don't seem to help that since it is foundation wall. Also the slab will come up to frame wall not concrete wall. The other issue is that it will draw it all at the height of stem wall. Your top plates will not be right up to the the joists and no adjusting. 2 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 8, 2016 Share Posted July 8, 2016 Good points Jerry. Link to comment Share on other sites More sharing options...
dshall Posted July 8, 2016 Share Posted July 8, 2016 Great question, great answer. Link to comment Share on other sites More sharing options...
joey_martin Posted July 8, 2016 Share Posted July 8, 2016 Another reason...and the most important to me for keeping those basement wall as 2, is the ability to control the walls for construction docs. I want the ability to control the line type and color of that framed portion so that I can show it on both the basement floor plan, and the foundation plan with the appropriate line. Link to comment Share on other sites More sharing options...
dshall Posted July 8, 2016 Share Posted July 8, 2016 Another reason...and the most important to me for keeping those basement wall as 2, is the ability to control the walls for construction docs. I want the ability to control the line type and color of that framed portion so that I can show it on both the basement floor plan, and the foundation plan with the appropriate line. Great comment, I am assuming the retaining wall and the inside framed "furred wall" are on two different layers so you can control the line weight and style. Good stuff Joey. Link to comment Share on other sites More sharing options...
joey_martin Posted July 8, 2016 Share Posted July 8, 2016 Yes. And fill the basement framed walls (if you choose to fill them) with the WALL FILL tool rather than in the wall type setup, so that the fill can be controlled by a layer as well, separate from the fill of the retaining/stem walls. Link to comment Share on other sites More sharing options...
dshall Posted July 8, 2016 Share Posted July 8, 2016 Yes. And fill the basement framed walls (if you choose to fill them) with the WALL FILL tool rather than in the wall type setup, so that the fill can be controlled by a layer as well, separate from the fill of the retaining/stem walls. Another good tip. I have never used the wall fill tool because it is an extra step. It might be a good option...... I have to think about this............... the wall type setup fill can be controlled by layers..... so the question is..... is there a time that I would want the wall fill shown yet I would not want to see the wall layers....... if I only want to see the wall fill when the wall layers are turned on, I do not think the wall fill tool will be necessary. Link to comment Share on other sites More sharing options...
johnny Posted July 8, 2016 Author Share Posted July 8, 2016 Good stuff guys - thanks! Link to comment Share on other sites More sharing options...
