Array command, need a better method
ACADuser
I build an extension to the table of contents on a plan to accommodate sheets I do not generate.
The horizontal likes need to be quite accurate to fall between the new text.
I measure but at 3/16 the rounding chief does at that small a measure is off.
In Autocad I just Pick the measurement which is quite accurate.
I doubt Chief will add this feature to its dialog boxes as not enough people are asking for it.
So what is the best way to get the accurate measurement?
Is there a better way to do this?
OK Thanks Alan, that helps.
Playing with plain text I was able to create a text object & align the vertical lines to match the Index.
This was the way to go only I could not conquer the Text table elements, Now I have a better understanding.
SO I no longer need the cobbled table I created.
I agree with Richard's method - and that is what I do for sheets I'm not preparing....but, id also say you dont need to have lines between the text either.  I suppose if that is how you want it, but I personally turn those lines off anyways.
