Steve-C Posted April 27, 2016 Share Posted April 27, 2016 Prior to X8 this camera view had a fixed point that stayed put when zooming or rotating. Now it seems to jump all over the place, so I'm constantly going back to plan view to center the camera in the plan. Is there a setting I'm missing somewhere? Link to comment Share on other sites More sharing options...
dshall Posted April 27, 2016 Share Posted April 27, 2016 On 4/27/2016 at 3:19 PM, Steve-C said: Prior to X8 this camera view had a fixed point that stayed put when zooming or rotating. Now it seems to jump all over the place, so I'm constantly going back to plan view to center the camera in the plan. Is there a setting I'm missing somewhere? Yes please, ...... I think the answer we will get is when we zoom in and out, in previous releases, the camera stayed put but the focal angle changed, now the CAMERA MOVES, I Think i liked how it worked before. Anybody have any hints? Link to comment Share on other sites More sharing options...
jscussel Posted April 27, 2016 Share Posted April 27, 2016 I also see this as a problem. Liked the old way. I think the change has to do with the 3D mouse. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted April 27, 2016 Solution Share Posted April 27, 2016 Switch to Perspective Crop Mode under Camera View Options. That will take you back to the way it was before. If you're not in Perspective Crop Mode, the camera isn't simply jumping around its actually moving wherever you take it. When you zoom in on something the camera is actually moving closer. When you pan, the camera is moving over. Link to comment Share on other sites More sharing options...
dshall Posted April 27, 2016 Share Posted April 27, 2016 On 4/27/2016 at 4:35 PM, Alaskan_Son said: Switch to Perspective Crop Mode under Camera View Options. ..... Thanks Michael, but where is camera view options? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 27, 2016 Share Posted April 27, 2016 On 4/27/2016 at 5:32 PM, dshall said: Thanks Michael, but where is camera view options? 3D tab sir. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 27, 2016 Share Posted April 27, 2016 Has anyone else noticed that the "3D Focus on Object" doesn't always work? It seems to work and then if you try to select another object it doesn't work. Link to comment Share on other sites More sharing options...
Steve-C Posted April 27, 2016 Author Share Posted April 27, 2016 On 4/27/2016 at 4:35 PM, Alaskan_Son said: Switch to Perspective Crop Mode under Camera View Options. That will take you back to the way it was before. If you're not in Perspective Crop Mode, the camera isn't simply jumping around its actually moving wherever you take it. When you zoom in on something the camera is actually moving closer. When you pan, the camera is moving over. Many thanks! Link to comment Share on other sites More sharing options...
dshall Posted April 27, 2016 Share Posted April 27, 2016 On 4/27/2016 at 5:35 PM, Alaskan_Son said: 3D tab sir. Thanks, but it still does not work for me the way it did... it works differently... see the pic, this is a camera overview and the "...CROP..." option is greyed out. If I do an interior shot... again it does not work like it worked before (camera stays in same location) I will need to learn a different method. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 27, 2016 Share Posted April 27, 2016 On 4/27/2016 at 6:42 PM, dshall said: Thanks, but it still does not work for me the way it did... it works differently... see the pic, this is a camera overview and the "...CROP..." option is greyed out. If I do an interior shot... again it does not work like it worked before (camera stays in same location) I will need to learn a different method. Ahh...now an ORTHOGRAPHIC camera view is a different story. I don't believe that works any differently than it ever has. What are you experiencing that is different than it used to be? Link to comment Share on other sites More sharing options...
glennw Posted April 28, 2016 Share Posted April 28, 2016 Michael is correct. The tool is called Perspective Crop Mode. Link to comment Share on other sites More sharing options...
Jodi_DoubleU Posted May 6, 2016 Share Posted May 6, 2016 Hello Everyone, The steps to take are as follows: If you take a 3D perspective camera view, then go to 3D> Camera View Options>Perspective Crop Mode, you will get the results you are after. Best Regards, Jodi W Technical Support Analyst Chief Architect Link to comment Share on other sites More sharing options...
ddaigle Posted May 16, 2016 Share Posted May 16, 2016 Do we have to do this every time we open a perspective overview? Is there a way that we can make it default, and avoid the extra step? When taking exterior shots, I prefer the crop mode. Thanks, Dru Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 16, 2016 Share Posted May 16, 2016 On 5/16/2016 at 1:40 PM, ddaigle said: Do we have to do this every time we open a perspective overview? Is there a way that we can make it default, and avoid the extra step? When taking exterior shots, I prefer the crop mode. Thanks, Dru There doesn't seem to be a default setting for this (although I could be missing it). You can simply hit the P button though to toggle the crop mode on and off. Link to comment Share on other sites More sharing options...
Steve-C Posted May 16, 2016 Author Share Posted May 16, 2016 I added the crop tool to my perspective view toolbar, it saves a little time. Link to comment Share on other sites More sharing options...
