Designer100 Posted April 6, 2016 Share Posted April 6, 2016 can anyone assist. across the front of this kiosk. I need 2' - 15' - 2' . all the sides and back need to stay as they are. I have locked sides and rear. but cannot seem to get it to change the 2 angles to 2' w/o changes other walls? Also this si to have a 12' maximum ht semi- arch roof across the front. ceiling inside is to be 8'. I made defaught 8' ceiing inside. do I make the rest of ht wall 4' to fit under arched roof to be attic. Also going to be metail roll up door openings at 15 ft and the corners client wanted to roll up, but then I do not think that would work. Do anyone have a roll up 3d door I can use. it would be above the 34" counter that will overhang 14" out from the wall under rollup doors (windows). Help would be appreciated. Chief Architect x8 newell.cheatheam@gmail.com Frankys.plan Link to comment Share on other sites More sharing options...
Kiwideziner Posted April 6, 2016 Share Posted April 6, 2016 what angles?? the plan is a rectangular building 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted April 6, 2016 Share Posted April 6, 2016 I used a rectangle for snapping and breaking the wall line. Frankys aaa.plan Link to comment Share on other sites More sharing options...
joey_martin Posted April 6, 2016 Share Posted April 6, 2016 Looks like Alan has it handled....but as an aside, this reminds me of the center field concession areas at Victory Field here in Indianapolis. Great ballpark. Link to comment Share on other sites More sharing options...
Designer100 Posted April 6, 2016 Author Share Posted April 6, 2016 solved just go to work on semiarch roof and glass and metal front. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 6, 2016 Share Posted April 6, 2016 I would be happy to go to work on the semi-arch. Who do I send the proposal to? 1 Link to comment Share on other sites More sharing options...
justmejerry Posted April 6, 2016 Share Posted April 6, 2016 Your angled walls are what you wanted for sizing and even put roll up doors and roof. Frankys GHD2.plan Link to comment Share on other sites More sharing options...
