clfrycreative Posted January 8, 2016 Share Posted January 8, 2016 I upgraded to X7 but had some problems with performance due to an old graphics card, so yesterday I upgraded the card. All of my problems went away, but left me with a new problem that I don't remember having before (I hadn't used it much before updating the card)... In Chief, and only in Chief, the mouse pointer/crosshairs seems to have a delayed, kind of rubber band response to movement... I played with the mouse speed in windows; regardless of the mouse speed, it still does it. Also, outside of the editing area it does not do it; if I move to the tool bars, library, open an item or dialog, etc, it is normal. Could it be possible that there is a chief setting regarding this, or do I need to return this card? Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted January 8, 2016 Share Posted January 8, 2016 Might want to check with Support but with Chief Nvidia based cards with the latest drivers is the way to go. Not sure what card you bought... Link to comment Share on other sites More sharing options...
clfrycreative Posted January 8, 2016 Author Share Posted January 8, 2016 On 1/8/2016 at 4:27 PM, Rashid_Garuba said: Might want to check with Support but with Chief Nvidia based cards with the latest drivers is the way to go. Not sure what card you bought... It's a Radeon R7 240 (Diamond). I'm very limited with what will physically fit in my Optiplex 755 tower, and these are known to work with my system (even some low profile cards still won't fit). These are supposedly the most up to date drivers for this card... tempted to allow the update to Win 10 and see if anything changes. Also, FWIW, everything is fine in AutoCAD and elsewhere. Link to comment Share on other sites More sharing options...
clfrycreative Posted January 8, 2016 Author Share Posted January 8, 2016 I just found that if I disable crosshairs, the pointer responds normally. I like using crosshairs though, coming from an AutoCAD background, but I think that slight lagginess would drive me nuts. BTW, I switched to an Asus model of the R7 240, with the same "issue". Link to comment Share on other sites More sharing options...
glennw Posted January 8, 2016 Share Posted January 8, 2016 Have you checked Cross Hairs...Synchronize With Cursor? Link to comment Share on other sites More sharing options...
clfrycreative Posted January 9, 2016 Author Share Posted January 9, 2016 On 1/8/2016 at 11:44 PM, glennw said: Have you checked Cross Hairs...Synchronize With Cursor? Yea, that's the way it was by default and where I was having the problem. For some reason the cross hairs are causing the lag; when I turned them of, the pointer moved normally and kept up with the mouse perfectly. I tried non-synch too, and the crosshairs couldn't keep up with the cursor, which was normal. Unfortunately I also can't seen to get dual monitors to work on these cards for some reason though (for some reason the computer doesn't detect anything plugged into the DVI port on either card), so I might try an older/lower tech card with PCIe V2.0 instead of 3.0... maybe I'll get lucky and that'll have an effect on the cross hairs as well. Always something. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 9, 2016 Share Posted January 9, 2016 I had that same (crosshairs) problem a few versions back but they fixed it a long time ago. Link to comment Share on other sites More sharing options...
VHampton Posted January 9, 2016 Share Posted January 9, 2016 On 1/8/2016 at 3:32 PM, clfrycreative said: Could it be possible that there is a chief setting regarding this, or do I need to return this card? I noticed the same thing too a while back. Do not return you graphics card. Turn down the undo/redo settings. ...or turn them off altogether Turning this feature off immediately stops your mouse from bogging down. Link to comment Share on other sites More sharing options...
Canuck Posted January 9, 2016 Share Posted January 9, 2016 Bummer, I just ordered new PCs built for the office based on the recommendations on the X8 page. Now I'm concerned about parts going into the machines that may not play well with CA. I sure hope I'm not paying for upgrades after all the time it took putting these together... Link to comment Share on other sites More sharing options...
clfrycreative Posted January 10, 2016 Author Share Posted January 10, 2016 On 1/8/2016 at 4:27 PM, Rashid_Garuba said: Might want to check with Support but with Chief Nvidia based cards with the latest drivers is the way to go. Not sure what card you bought... FWIW, I found a Nvidia card (GeForce GT 730) that works in my machine, didn't make any difference. On 1/9/2016 at 5:20 PM, VHampton said: I noticed the same thing too a while back. Do not return you graphics card. Turn down the undo/redo settings. ...or turn them off altogether Turning this feature off immediately stops your mouse from bogging down. Interesting, I'll tinker with that and see what happens, but pretty sure it didn't do that with my old (ooold) card. I do like my undos though Link to comment Share on other sites More sharing options...
