Layout Issue
Designer100
But they did print.  Otherwise how could he have posted his example.
He attached the layout, not a printed copy of the plans.  Open that same layout and do a save as PDF through the print DBX and see what you get.  Even worse...have a whole set of plans printed up with those settings before you figure out whats going on.
File...Print...Drawing Sheet Setup...Drawing Margins...Right and Bottom should be zero.
Print>Drawing Sheet Setup>Drawing Margins
I know this is late in the game but these two answers were correct and easy to fix Newell's problem.
My question is to ask Newell if this is the way you fixed it or did you do something else? You said you figured it out but you didn't say what you did.
Respectfully
Yeah I see what you mean
