HamlinBC Posted December 14, 2015 Share Posted December 14, 2015 Ok, what am I doing wrong here. Seems like this used to work ok, but now I have one gable that draws a goofy boxed eave up higher, and the opposite gable looks fine. *heavy sigh* I seem to always struggle with this feature... Boxed Eaves.zip Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 14, 2015 Share Posted December 14, 2015 Without downloading, looks like an attic wall that just isn't filling in. Just try to drag it to the end. you could also balloon frame the lower wall to fill that in Link to comment Share on other sites More sharing options...
HamlinBC Posted December 14, 2015 Author Share Posted December 14, 2015 ...ok...but the boxed eave is still there?... Link to comment Share on other sites More sharing options...
dshall Posted December 14, 2015 Share Posted December 14, 2015 I do not see the problem. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 14, 2015 Share Posted December 14, 2015 Downloaded it and it's a tough one ,looks like a bug. send it in I tried separating the roof planes, not sure what it is. maybe someone else can do it. Should be something easy if it isn't a bug. Scott I see it in X7 Good it works in an apple machine. Link to comment Share on other sites More sharing options...
dshall Posted December 14, 2015 Share Posted December 14, 2015 Downloaded it and it's a tough one ,looks like a bug. send it in I tried separating the roof planes, not sure what it is. maybe someone else can do it. Should be something easy if it isn't a bug. Scott I see it in X7 Good it works in an apple machine. Interesting, I saw it in x7 but it's good in x8 Link to comment Share on other sites More sharing options...
HamlinBC Posted December 14, 2015 Author Share Posted December 14, 2015 Hmmm...weird. I also don't see it in X8. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted December 14, 2015 Share Posted December 14, 2015 I think the reason CA does that is because you would never frame this way in reality. Why would you build one roof on top of another, and what will carry that roof load when it lands in the mid span of the main roof. You have an open kitchen below and the rest is the bedrooms. You have overall rafter length almost 20' and you dropping porch roof right on top of it. Maybe CA thinks there should be a ridge beam and that is why it comes out that way. IMO this is not a bug, because if you frame that roof as you would frame it normally in a situation like this, CA does what it suppose to do... But what do I know Link to comment Share on other sites More sharing options...
country Posted December 14, 2015 Share Posted December 14, 2015 That appearance works fine with trusses. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 14, 2015 Share Posted December 14, 2015 I think the reason CA does that is because you would never frame this way in reality. Why would you build one roof on top of another, and what will carry that roof load when it lands in the mid span of the main roof. You have an open kitchen below and the rest is the bedrooms. You have overall rafter length almost 20' and you dropping porch roof right on top of it. Maybe CA thinks there should be a ridge beam and that is why it comes out that way. IMO this is not a bug, because if you frame that roof as you would frame it normally in a situation like this, CA does what it suppose to do... But what do I know Greg ,here we call it California overbuild framing an it's done a lot. In fact , that's the only way you can build it here without putting in extra beams. Weather you put a beam in or not, won't make any difference here. Chief isn't that smart. I still think its a bug. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted December 14, 2015 Share Posted December 14, 2015 I never use them, around here trusses only used on tract home or condo or townhouse developments. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 14, 2015 Share Posted December 14, 2015 I hardly ever use trusses, I do show existing trusses when present but my cheap builder clients would never want to truss build, ever. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted December 14, 2015 Share Posted December 14, 2015 You right Perry, I see it on decks here. etc you attach a simple deck to a house it will put 8 footings where in reality you would need 3-4... As this little dilemma goes, it could be a bug.... But it seems in some situations and I see a lot on the plans that some guys post in here, that if you try to build something the way you would never do it in reality, something gets screwed up along the lines, whether this being a roof, attic wall or something else. Link to comment Share on other sites More sharing options...
blayman Posted December 14, 2015 Share Posted December 14, 2015 Seems to me the problem is you have not connected the roof planes. Once they are snapped together the extra fascia and box are gone. Bill Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 15, 2015 Share Posted December 15, 2015 Bill, I tried that, did your have the overbuild remain, what's the secret. Also what version. Link to comment Share on other sites More sharing options...
glennw Posted December 15, 2015 Share Posted December 15, 2015 If you drag the inside roof edge (of the thin bit of roof running down the gable wall) back to inside of the wall, the upper boxed eave disappears. Link to comment Share on other sites More sharing options...
HamlinBC Posted December 15, 2015 Author Share Posted December 15, 2015 Just to catch up, we strictly use trusses around here....for everything, and although this type of roof ISN'T common, we've done it before and this issue hasn't come up in the past. That would actually be one truss (with the kink in it). It would bear on the two walls and cantilever over the porch. Then they would frame a fake eave coming down to make it look like two trusses. On occasion someone will have a roof that needs handframed, but otherwise no. @Bill...not really sure what you mean. They've been mated, snapped, etc...and still shows. @Glenn...I was able to drag the roof to the framing layer, and it went away. But then I had to drag and mess with the wall to make it cover the gaping holes in the wall. What's more peculiar, is that the opposite side doesn't do that. Link to comment Share on other sites More sharing options...
