VinnieVicon Posted April 17, 2014 Share Posted April 17, 2014 Hello All, I'm building a deck for a great client and they want Keuka Cable Rail. Chief doesn't have this rail system in the library. Can anyone direct me to where I can download this system,if not how can I make this post and cable rail in Chief. We need to stretch our design wings. See attached photos Vinnie Link to comment Share on other sites More sharing options...
Kenoeightspot Posted April 17, 2014 Share Posted April 17, 2014 http://www.keuka-studios.com/keuka-installation.aspx Link to comment Share on other sites More sharing options...
Kbird1 Posted April 17, 2014 Share Posted April 17, 2014 Didn't DMDz make something like this ? maybe on the old forum or his site....don't think I have it but will check as I am still not sure how it passes code since it is "climb-able". M. Update: He did do something very similar , here is the post on the old forum , it includes a 40 " section with 2 posts and cables ,( resizable) and the post and cables as separate elements. it actually looks like the Chicago Rail I think: http://www.keuka-studios.com/the-chicago-style.aspx DMDz' s Library http://www.chieftalk.com/showthread.php?23366-One-New-FREE-Symbol-Each-Week&p=293835&highlight=railing#post293835 Link to comment Share on other sites More sharing options...
VinnieVicon Posted April 17, 2014 Author Share Posted April 17, 2014 Thanks Guys Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 17, 2014 Share Posted April 17, 2014 Of course, you could model your own newel post, add to the library, and then use a railing with panels; use your new newel with the cable railing panel in the library. Link to comment Share on other sites More sharing options...
imodel Posted April 19, 2014 Share Posted April 19, 2014 Such a cool looking cable rail I thought I would give it a go. My approach is a little different than those suggested. The railing system has a nautical feel to it, don't you think? Cable Rail.zipFetching info... 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 19, 2014 Share Posted April 19, 2014 imodel, VERY nice!!! Link to comment Share on other sites More sharing options...
Kenoeightspot Posted April 19, 2014 Share Posted April 19, 2014 Great Job. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 20, 2014 Share Posted April 20, 2014 Very kewl. What did you use for modeling the newel? This one is a wonderful display of what can be done with the molding tool. Stacking up the cables, each with its offset and height done to follow the curve, is a great way of using the Chief tool. Link to comment Share on other sites More sharing options...
VinnieVicon Posted April 20, 2014 Author Share Posted April 20, 2014 Thanks for this, but how can I draw those deck rails in my plan? Link to comment Share on other sites More sharing options...
VinnieVicon Posted April 20, 2014 Author Share Posted April 20, 2014 It looks to me like you built the deck with railings then made the invisible and the attached the Keuka rails to the band joist. The problem I'm having is getting the post and cable into my library from your model. Any thoughts? Vinnie Link to comment Share on other sites More sharing options...
imodel Posted April 20, 2014 Share Posted April 20, 2014 I modeled the newel from the 2D cad file that the manufacturer is kind enough to have on their website. Then imported as a "millwork" symbol that can be added to the library and used in a system railing that is visible. But I like getting exacting results in a short time. Don't like to fuss too much. I detached a single segment for the railing and blocked "architectural block" which can be added to the library. So you need to unblock from library and then you drag past corners adding breaks at corners and insure snapping is getting you exact. I have attached the two parts in a library here. Glad you guys like it! Keuka Cable Rail.zipFetching info... 2 Link to comment Share on other sites More sharing options...
VinnieVicon Posted April 20, 2014 Author Share Posted April 20, 2014 Thanks imodel I'm back from holiday visits; I'll give this a try and I really appreciate your help. Vinnie Link to comment Share on other sites More sharing options...
VinnieVicon Posted April 20, 2014 Author Share Posted April 20, 2014 Now that you mention how to take the 2D image and add to the library, I did take that training course but a blank it out for some reason, thanks again. Link to comment Share on other sites More sharing options...
woodcraftdesign Posted April 24, 2014 Share Posted April 24, 2014 wow, thanks, this is a good addition to the library. Link to comment Share on other sites More sharing options...
