Dennis_Gavin Posted August 12, 2015 Share Posted August 12, 2015 I seem to have forgotten how to do this and the help is not helping. I want to try and created the attached fixture. I am trying to distribute a thin ":ED strip" with a small yellow "light" in it's center along a line. SPlines don't seem to work. Also not having luck with a arc. I only get the attached dbx with only the first selection operable. ANy help appreciated! Link to comment Share on other sites More sharing options...
glennw Posted August 12, 2015 Share Posted August 12, 2015 Dennis, Should you be using Build...Distributed Objects...Spline Distribution Path? Link to comment Share on other sites More sharing options...
rlackore Posted August 12, 2015 Share Posted August 12, 2015 You have to create the path as a Distributed Object. Then open the path and the dbx should be self-explanatory. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 12, 2015 Share Posted August 12, 2015 -and make sure you turn on the "Electrical" Layer or whatever Layer your Lights are on. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted August 12, 2015 Author Share Posted August 12, 2015 Thanks Glenn and others. I was getting the dist. obj icon on the task bar but never look at the Build menu.<br />That should do it.<br /><br />Thanks guys!!<br /><br /> Link to comment Share on other sites More sharing options...
Kbird1 Posted August 13, 2015 Share Posted August 13, 2015 looks like time to turn your Full Editor Options back on again D. M. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted August 13, 2015 Author Share Posted August 13, 2015 Mick - Yeah I noticed that. How did that get changed?? Link to comment Share on other sites More sharing options...
