Error Message?
Larry_Sweeney
Larry
Could be permissions were changed for either the Archive folder or the Boyd Station file
Worth looking at anyway, as it apppears the auto save path is correct, but CA is confused because the write could not execute
To check the permissions - open ......X6 Data - then right click on the Archives folder
Properties-Security : All Allow permissions should be checked (with the exception of the last - Special permissions)
If not - just use the Edit button to correct
Open the Archives folder and do the same routine for the Boyd Station file
Permissions have been known (rarely) to alter so it is long shot
Good luck
Randy.......Checked out the items you mention and everything checks out okay. I sent in a ticket to see what Support has to say. Since I'm not very "computer savvy", whenever I get any "pop up message" I get nervous real quick. Appreciate the advice. I'll let you know what Support says. Have a great day.
