Can I add a lower floor after creating 1st floor
PLL26house
I have finished creating the first floor and now realize that I need to create a walk-out basement under it.  I can see how I can add a floor above the 1st floor, but I can't find a way to put one under it with Suite 2015.  Any suggestion because I don't want to have to redo the entire first floor.
BTW: with HD Suite you should be using the Hometalk forum
the Chieftalk forum is for Chief Premier users
while HD PRO users can benefit from following Chieftalk also
other HD products are too limited to find any real benefit
Lew
The OP may have wanted to put a floor in and then the foundation level. I will ask the question about doing this in X7. Could I just copy the Main level up to a new second floor and do the walkout on floor 1 if I wanted to?
