Ronniego Posted July 12, 2015 Share Posted July 12, 2015 My customer wants a storm door on the front of his house. How to draw that with the front door swinging in and the storm door swinging out from the same opening. Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2015 Share Posted July 12, 2015 placing a 2nd door next to the existing Ext. door , then use the CTRL Key to drag the 2nd door over the Existing Door works, probably best to setup the 2nd Door's Specs in DBX 1st , as selection of each one will be harder after overlaying them. M. 1 Link to comment Share on other sites More sharing options...
Ronniego Posted July 12, 2015 Author Share Posted July 12, 2015 Thanks Mick Link to comment Share on other sites More sharing options...
chief58 Posted July 13, 2015 Share Posted July 13, 2015 There are storm doors in the lib also that I have used for this Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted July 13, 2015 Share Posted July 13, 2015 Ray - where in library? Can't seem to find it. Link to comment Share on other sites More sharing options...
chief58 Posted July 13, 2015 Share Posted July 13, 2015 Dennis sorry just got back in the office, if you do a search under screen door they come up on mine Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted July 13, 2015 Share Posted July 13, 2015 Maybe in your user catalogue? No biggie. Don't need one was just curious. Link to comment Share on other sites More sharing options...
JLDrafting Posted July 13, 2015 Share Posted July 13, 2015 I don't recall where this came from, but it was on my back-up machine that has X6. I upgraded my computer and did not migrate from it. screen door.plan 1 Link to comment Share on other sites More sharing options...
dshall Posted July 13, 2015 Share Posted July 13, 2015 I don't recall where this came from, but it was on my back-up machine that has X6. I upgraded my computer and did not migrate from it. Nice Jim, thanks. However I never need one here in SOCAL, placing a 2nd door next to the existing Ext. door , then use the CTRL Key to drag the 2nd door over the Existing Door works, probably best to setup the 2nd Door's Specs in DBX 1st , as selection of each one will be harder after overlaying them. M. Nice tip Mick. Which got me to thinking..... how about a double action door.... of course in the door dbx you can spec double swing... now you can also spec to show the door open in 3d.... now the question is, it's double swinging, it is shown open in 3d, but you want it to swing in the opposite direction in 3d, can you do it? Yes, jiggle it and gaggle it and you can have the door swing out instead of in in a 3d view......... Mick, your tip just got me playing with options, thanks. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 13, 2015 Share Posted July 13, 2015 The double swing never looked right to me , so while trying two doors with there frames 1/2 the width of the wall each I found I didn't need to get fancy CA melded them together no problem, and still let me have both doors. I think last time I might have just done a copy in place and reversed the swing side of the copy and changed the door type, but not at computer now to verify that. M. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 13, 2015 Share Posted July 13, 2015 Thanks, Jim; nice door. Mike Link to comment Share on other sites More sharing options...
