Adam_Gibson Posted July 10, 2015 Share Posted July 10, 2015 Rather, I cannot get them to stay clipped if another cabinet touches or is close to its side. As it's common to clip a deeper depth cabinet when placing a sink or cooktop in a deeper cabinet (27"), what do y'all do in this circumstance? Link to comment Share on other sites More sharing options...
dshall Posted July 10, 2015 Share Posted July 10, 2015 .......what do y'all do in this circumstance? .... if you convert to custom countertop, you can do whatever you want. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted July 10, 2015 Author Share Posted July 10, 2015 There is a custom counter top. The cabinet still doesn't clip when another one touches it. Link to comment Share on other sites More sharing options...
dshall Posted July 10, 2015 Share Posted July 10, 2015 There is a custom counter top. The cabinet still doesn't clip when another one touches it. oh..... sorry Mick, I am going against my new tenet, post the plan Adam........ the cabinet will not clip itself, you have to clip the cabinet yourself. Cabinets do not clip themselves. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted July 10, 2015 Author Share Posted July 10, 2015 Here's the plan. Man, the website rejected it three times first. Thanks for taking a look. The cabinet in question is the one containing cooktop. Montomery 02.plan Link to comment Share on other sites More sharing options...
jcaffee Posted July 10, 2015 Share Posted July 10, 2015 I think this was a known issue. If there is 3" separation, then the cabinet won't clip. However it works fine with 4". (doesn't help with standard depth cabinets though) jon Link to comment Share on other sites More sharing options...
MarkMc Posted July 10, 2015 Share Posted July 10, 2015 Jon has it pretty much- Place a 21 deep cabinet next to a 24 with a 3" clip and the clip goes away. You can change either the clip depth or the cabinet depth by 1/16" and the clip returns. OTOH-If you need to place 24" deep clipped cabinets on each side of a range you will get the clip next to the range where it is unwanted. To remove clip on the range side add a 1/16" wide by 24" deep cabinet between the range and the clipped cabinet to make the clip dissappear- of course that mucks up your dimension and the schedule. I have yet to find a work around for the dimension issue. Link to comment Share on other sites More sharing options...
jcaffee Posted July 10, 2015 Share Posted July 10, 2015 Yep, known issue. There was a fairly lengthy thread awhile back. X8 Beta should coincide with the UGM in September' I'll keep my fingers crossed that all anomalies within CA get fixed in X8. jon Link to comment Share on other sites More sharing options...
Kbird1 Posted July 10, 2015 Share Posted July 10, 2015 oh..... sorry Mick, I am going against my new tenet, post the plan Adam........ the cabinet will not clip itself, you have to clip the cabinet yourself. Cabinets do not clip themselves. by now you would think it was standard practice, there are just too many things (DBX's) to check ..... My, you are Really Optimistic Jon "X8 Beta should coincide with the UGM in September' I'll keep my fingers crossed that all anomalies within CA get fixed in X8". Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 11, 2015 Share Posted July 11, 2015 by now you would think it was standard practice, there are just too many things (DBX's) to check ..... My, you are Really Optimistic Jon "X8 Beta should coincide with the UGM in September' I'll keep my fingers crossed that all anomalies within CA get fixed in X8". I don't know how Chief would fix everything you want. but you can hope. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 5, 2016 Author Share Posted April 5, 2016 Well, X8 is here and so is the problem! PITA! Link to comment Share on other sites More sharing options...
MarkMc Posted April 5, 2016 Share Posted April 5, 2016 Yeah still there. They did fix the toe kick on the clips though and I'll take what they did to cabinet sides over fixing this 10 days out of 7. OTOH I discovered a much easier fix. -shift select the cabinet and block it-the clips will be persistent. You can block the cabinet with clips, block then tab the block to open it and add clips-doesn't matter if a cabinet is already next to it or not- the clips will show up (on all 4 corners though) It does not solve the issue of having clips on one side with a range on the other but hey...can't always get what you want. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted April 5, 2016 Author Share Posted April 5, 2016 Interesting. Thanks Mark. Link to comment Share on other sites More sharing options...
