Sign in to follow this
Context
Legend and symbols in Layout
I am creating my template for layout with a construction notes page.  On this page I want to put  General Symbols and Legend.  When I go to my Library browser and find an electrical outlet for instance, it won't let me put it in with a CAD box or just on the page. What's up with that?
those kinds of symbols need a wall to let them insert ,  instead use Chief's Plan Notes and legends in the CAD Block Library , you can unblock them and edit if needed.
You can place an outlet floating in space but the electrical items from the library don't seem to want to drop into layout. You would need to build your legend in a plan file and then bring the legend from the plan file to the layout file. Or make a cad based one that you store in the library and then drop into layout. See image for an easy outlet to float for creating the legend.
My electrical legend which is partially made from cad lines for the electrical items
Chiefs legend location
  • Downvote 1
I do all my electrical legends in a cad detail. To get the cad block (not the symbol), either place the "cad block management" tool on your toolbar and get it there or go to the cad tab at the top toolbar and go down to "cad block management" and get the cad block there to place in the plan or cad detail. If your not sure which cad block it is then go to the plan and select the symbol>open symbol (not open item) and check to see what the cad block name is for that symbol.
Good tip Tommy
Context.....to place a CAD Block  in your Plan from the CAD Management Tool , find the one you want on the list and click the insert button , and you can then drop it ,with a click onto your plan page.
Want another tip? If you insert the cad block for the telephone from the cad block management, the cad block comes with fill. You'll have to unblock it and remove the fill if you want it to match the cad block that is assigned to the symbol in the plan.
The problem is that I have the interiors version - no wonder I am struggling!  I don't have those options in this version of Chief - Grrrrr.
The problem is that I am using the Interiors version of this program.  It's dumbed down and doesn't have notes and legends - no wonder I am struggling.  Grrrrr.  Since when do interior designers not use notes and legends???????  Grrrrr.
I started on Interiors and whined at CA about that and a few other things for a year or two. At that time I was exporting to CAD and importing. When I finally could afford it I bit the bullet and upgraded to Premier- should have done it sooner instead of running into a wall. I quickly recovered the the cost in productivity quickly as soon as I started using annosets.
Thanks Mark, I have figured that out, too.  I think it's a way to get more users that are reluctant to foot the bill for the entire program.  Unfortunately, I really don't need much more than what is offered, but the annosets, would be nice.
Actually they talked me down from Premier to begin with-"you really don't need that"
I just disagree with how it is named/marketed.
I don't use terrain, rarely roofs, rarely framing (but handy occasionally)- other features are worth the cost : detail to view (for cabinet openings and as built plans) project browser and annosets for convenience and speed. Besides it's a one time cost-still cheaper than 2020 and much better- support is the same cost for Premier and Interiors I believe.
    27501
    B1k3rm4n
    B1k3rm4n
  • Similar Content
    • By grizzdj
      Hello Friends- I am working on a distillery plan and was wondering if there was a catalog or CA source for distillery symbols like stills, fermenters, mashtuns, chillers, etc.
      Thank You In Advance
      Dan Johnson
    • By PrimeArch
      Hello guys. I made a custom symbols and model for my electrical because CA dont have it.
      I managed to make it but the problem is  they cannot stay side by side.. they will merge  like this
      Btw the can stay side by side if each of em not the same height
      How do i solve this? Please help
    • By nancyscial
      Hi
      I am using x10.  I have a kitchen type that I will multiply many times and save by unit #. I need to have the unit # show up on my layout page for each plan that is saved.
      Not sure how to save the units and have the info show up.
      Thanks in advance!
    • By WAShideler
      I am hoping someone can tell me how to handle this.  I have done all the framing, and using the project browser, sent all the Wall Details to a Layout page.  When I first did this, everything showed up perfect...The wall detail names on the walls in plan view, corresponding to the labels in the Layout.
      Well, I made a couple of window changes, rebuilt floors and ceilings and now what I have is this: The wall detail numbers show up correctly in the plan view, but the layout shows: "Wall Layer 4 Viewed from outside".  I must be able to change the Views on the Layout to correspond with the plan view!
      HELP!!!!
      TIA
      Bill
      Funky Labels.pdf
      Plan View.pdf
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      CLOUD SYNC MULTIPLE USER LIBRARIES FOR MULTIPLE DEVICES/END USERS       DIRECT LINK TO VIDEO X64 SHELL EXTENSION  X32 SHELL EXTENSION PAYPAL THE GUY THAT WROTE THE EXTENSION  ADVANCED LIBRARY SEARCHES DIRECT LINK TO VIDEO       INTRO TO ADVANCED PBR METHODS DIRECT LINK TO VIDEO CREATING ADVANCED MATERIALS IN PHOTOSHOP   DIRECT LINK TO VIDEO AUTUMN LEAVES MATERIAL FILE CREATE A HOTKEY TOUCHPAD USING YOUR ANDROID OR IPAD TABLET     DIRECT LINK TO VIDEO LINK TO SOFTWARE WEBSITE TOUCHOSC METHOD FOR CREATING CON-DOCS IN .PLAN      USING AN IPAD TO REMOTELY CONTROL CA. METHOD OVERVIEW   ADVANCED TOOLBAR CONFIGURATIONS   NEW!!! 08/28/2019
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
